Water Tank/Pump Set Up?
I'm not sure if this is the right place for this, but I can't seem to get this water tank set up figured out. I tried to run my pressure washer off the tank and nothing. I tried elevating the tank to see if gravity helped,....nothing.
I've read the previous posts and am not wanting to rig up a stationary pump system.
I use my SUV for ball practice for my boys, (loading a lot of gear), and I would like to be able to put in/remove the tank as needed.
Would it be possible to just secure the pump to a board and then connect it to the tank when needed? That way the pump is secure to the board, and when it's hooked to the tank, but when I need to take everything out, it can disconnect and be removed.
Most of my clients prefer to have their vehicles detailed at their home. So water wasn't an issue. With my business increasing, I'm hitting the office complexes and need to be entirely mobile.
I appreciate all feedback, and thank you for your time.
Shawn
Re: Water Tank/Pump Set Up?
You need a 12 volt pump that goes from the tank to the pressure washer. All you have to do is turn on the pump then start the pressure washer. Here is the model I use Shur-Dri SD-107. Picked it up a tractor supply for $80. I just changed the end to plug into my 12 volt port in the back of my Excursion.
Hope this helps Jim
I also use a 65 gallon tank that is strapped to a skid the I cut to fit the tank. The whole thing is then strapped to the rear third row seat brackets. Much like you I have to remove the tank to go racing. I made a cargo carrier to put the pressure washer & generator on. Plus a hose reel & no gas smell in the truck. I will try to post pics towmorrow.
Hopes this helps Jim
Shawn
I've never had an issue with gravity feeding my pressure washer(s).
What brand/size is your p/w? Do you know what brand of pump your p/w has on it already?
Thanks for the replies.
My bro in law is helping me set it up Saturday. I bought a 12v pump and am getting a generator Saturday.
I'm going to have the gen running outside of my suv. So gas fumes wont be an issue.
My pressure washer is a Karcher 1550.
Dragster, what adapter did u get for the pump, and does ur truck have to be runnning when you use the pump?
Thanks.
Go to harbor freight and buy their utility pump for around $26. It pumps 4 gpm. It uses a 12 volt dc power(car battery)
save yourself some cash.i know you want to remove it at times. But once you put water in it,you'll have to drain it to move it. 1 gallon of water weighs 8.34lbs. Do the math for say 70 gallons. Search post for mobile set ups, or pm me!
I use garden hose adapters with quick release. Put on on / off valve at the tank just to be safe. I have not had a problem without the truck running. But I have killed the battery with the barn doors open.
This year I am installing another battery.
While I don't know the mechanics of pressure washer pumps I have noticed that some PWs advertise ability to draw water from a bucket or tank, most don't. In any event, be careful not to run the pump dry.
This has been a struggle.
1. The Harbor Freight 12v pump has battery terminal clamps, a POS and a NEG. So I got an adapter that will plug into my 12v outlet in my truck. Well, it blew the 10amp fuse FAST. IT WAS HOT. Ok, dont want to fry my truck's electrical system, so have to go another route.
2. Purchased a gas powered PW, (sold the electric Karcher), and attempted to draw water from the tank using ONLY the PW. Didn't work. (The tank sits in the back of my truck, elevated, and the PW sits on the ground. Ran a short 6' hose from tank to PW. Nothing. So much for gravity.
3. Purchased a new generator with a 12v DC oultet where I can attach the stupid battery terminals to. Well, of course, the water pump fried that 10 amp fuse within seconds, that's on the generator.
4. Went to Harbor Freight AGAIN to possibly buy the larger electric pump that I could just plug into the generator. I open the box, and look at the pump, wait, where's the plug? apparently YOU have to wire it yourself. I'm a detailer, not an electrician.
Is this common to make these things without a plug attached? Who does that? Oh right, the Chinese.
I'm heading to Radio Shack now per Dragster's instructions. Thank you dragster. If anyone has any helpful tips, or not so helpful tips, please don't hesitate to share them with me.
Admittedly I'm not mechanically inclined. But this is driving me absolutely crazy. Sorry for the rant.
Sounds to me the 10 amp is probably burning out when the pump first comes on or very shortly after??
The pump as I see from harbor freight if correct, has a 7.5 amp startup which is probably blowing the fuse. Then kicks to a stable 5 amp. Try a 15 amp fuse.
7.5 amps and 50 watts should not blow a 15 amp fuse in your generator. Unless there is a short. But might just get to hot for a ten.
By batcat420 in forum Auto Detailing 101
Last Post: 02-06-2018, 10:44 AM
By 2modfast in forum How to make money detailing cars
Last Post: 01-05-2017, 01:46 PM
By mcglockin in forum Auto Detailing 101
Last Post: 01-05-2017, 01:44 PM
By Aririguzo in forum Auto Detailing 101
Last Post: 10-28-2014, 02:42 PM
By AjNavo61490 in forum Show N' Shine
Last Post: 05-17-2009, 02:42 AM
