I'm curious what everyone's process is for de-badging. By process, I mean what steps and products do you use for removing the badges which come with the car, and those pesky dealership stickers/decals?
Most dealer stickers can be removed with the heat from a hand held hair dryer. A lot of guys use fishing line for the factory glued on badges. You may find removal of some badges or emblems complicated with studs that the mounting holes required to fasten them on are unsightly. This subject has been discussed before on the forum by a member with a ford tailgate where it was mounted with studs thru the tailgate . Not all aplications will be the same and require different actions for the desired results. Paul S
Correction: The thread I was thinking about was on MOL.
Really thin fishing line (use thick gloves) and a blow dryer.
Heat up the badge really good and slide the fishing line behind it and moving side to side till you go all the way down. Use Goo Gone to get rid of any residue left over.
I did exactly what you posted, but found alcohol to work much better than Goo Gone.
+1
3M adhesive remover for any remaining glue and a plastic razor blade.
The plastic emblems which have a 2 sided foam tape holding them on require a little bit of dwelling time for the adhesive remover to work well.
Originally Posted by CieraSL
I've used dental floss with really good results. Let the car sit in the sun for a while so the badge gets nice and warm. The wax coating on the dental floss will make it glide smoothly between the badge and the body panel. You can remove the residual tape/glue with any number of different products.
