are you sure the spots are not mineral deposits ?? Although I would not usually suggest it. Try wiping a small area with CLR ... if it removes the spots its likely rust from the sprinkler system.
Thanks for the info. Tried the DP with the 0000... nothing. Gonna try the other stuff before maybe replacing the glass. Wife doesn't care if it gets better, but it's driving me crazy.
jm
KAIO and #0000 steel wool will work, but it's a long process. At least on my suv it was, took almost the whole day to do most of the truck. I would say 90% of the waterspots are gone now, still some etching that I could remove but it's barely noticeable so....
