I've noticed alot of posts suggesting using a 12 gauge extension for
polishers. Is this necessary for something that comes standard with
a 16 gauge power cord?
Thanks
The gauge is dependent on two factors: length of the cord and draw of the items at the end. While your appliance may have a 16AWG cord, that is for plugging directly into the outlet which typically is serviced by 12AWG wire.
For your appliance, I would use no less than 14AWG for runs up to 50 feet. If you plug several things into a multi-plug at the end of the run, such as a 500W light and a polisher, spend a couple extra dollars and use 12AWG.
I have an assortment of extension cords from 16AWG to 12AWG (mostly 25 feet).
Regards,
GEWB
Linux Reg. User #206357 (Feb. '99)
"Can't get there from here."
Personally I use a 10 ga. contractor grade cord by Rigid. When mobile I sometimes have to span a long way, and having to worry about not only a polisher but a steamer & extractor I had to go heavy. Awesome cords though, and the price between 12 and 10 ga. wasn't all that big.
