Re: 3M Clear Bra swirl marks removal suggestions?
Did you try rubbing alcohol? It works sometimes, but it is only when needed. Don't do it a lot.
Never tried that. I could try a tiny spot to test it out. I haven't done any paint correction to my car yet, but would going over it with a polisher using a swirl removal product be harmful?
FWIW, I've had great luck removing swirls on clear bras using the WG duo (TSR 3.0 and FG 3.0).
I've also heard of people using a lite polish. Like zaino Z-PC or Z-AIO. You want something with no petroleum in it. Petroleum yellows the clear bra.
Matt what pad did you use? I know the bra scratches easy, and heard of people using too aggressive a polish for it.
I have a couple of Menzerna products at the moment:
Menzerna SIP (PO83)
Menzerna Nano Polish (PO106)
Would either of those work on the clear bra?
I remember reading that a guy over on autopia used 106FA and a white LC pad for his 3m bra. He said it worked. He said to use low speed with light pressure. Too much heat will melt the plastic. SIP is too strong for a clear bra.
Cool. I do have an LC white pad as well. I'll have to try that out.
I've been able to use a few polishes with good results on them. As per the above post, use low speeds and don't get it too hot.
By zckid in forum Auto Detailing 101
Last Post: 10-14-2017, 07:12 PM
By spa in forum Auto Detailing 101
Last Post: 07-23-2017, 12:41 PM
By s1uma1 in forum Ask your detailing questions!
Last Post: 08-01-2016, 09:27 AM
By BentShaft in forum Ask your detailing questions!
Last Post: 01-29-2011, 11:04 AM
By Totoland Mach in forum Auto Detailing 101
Last Post: 11-05-2007, 09:22 PM
