Re: What do you use to prime your pads before use?
I think you supposed to prime the pad with the same compound that you will be using. It just have to worked into the pad itself. From what i understand, please correct me if im mistaken.
Use pad conditioner then work the product in with the tips of your fingers. After that just a few pea size dots of polish will do the job. Nothing worse than dry buffing.
Jimmie, the last time I primed my pad with pad conditoner using Menz, it gummed up my pads. Never tried it again. Maybe I just either used to much conditioner or not enough product. Dunno!
For a dry pad, I will use a very light mist of water, just enough to lightly dampen the surface of the pad. I then use just a bit more polish for the first pass and start off at the lowest setting and spread the polish around. This is with my UDM and LC CCS pads. I have not had any problems with this method and it seems to work good for me.
1982 Olds Cutlass - my summer toy.
1999 Suburban - Black of course!
2002 Bonneville - The Mutt, a mix of everything.
I don't think your alone Rsurfer. I've heard that about Menz (no conditioner). One that I learned from watching Ed at DFIII is spriting pad with H2O. That was with Optimum.
