Old 3M rubbing compound
I found old bottle of 3M rubbing compound while cleaning my garage. It says removes swirls and scratches.
I now have Menz IP and Menz PO106FA. Is this 3m rubbing compound still good for anything?
I do plan on doing a headlight restoration and sanding with 800-1500-2000 grit. Should I try the 3M rubbing compound or just go with the Menz IP with yellow pad?
Thanks.
Re: Old 3M rubbing compound
If that is the old reddish brown compound that is some strong stuff. I've never used it on auto paint but I did my bathroom counter tops with it. Before I knew what I was doing I worked it at 3000+ rpm's. Dusts like crazy.
Yeah you can use it on your headlights then work down with Menz.
Its actually a tan liquid. I guess its not THAT old. I went to wally world and saw it there still.
Same here. I was using it to try and hand polish out my 2000 grit sanding marks on my headlights. Light tan in color called "3M Rubbing Compound"
I've got an old bottle of the white finishing compound that HAS to be 6 years old for fun, and it still works fine. Having said that, all my chemicals get brought into the basement for the winter.
toss it ... to many "old" products just sit on shelve taking up space. Especially with the newer and easier to use products.
By Shawn328 in forum Ask your detailing questions!
Last Post: 08-06-2017, 02:49 PM
By bmwstephen in forum Auto Detailing 101
Last Post: 06-07-2015, 06:51 AM
By nlmiller1 in forum Auto Detailing 101
Last Post: 12-10-2013, 10:07 PM
By SilverHawk in forum Auto Detailing 101
Last Post: 07-09-2012, 04:02 PM
By Legaspi89 in forum Product Reviews
Last Post: 03-20-2012, 04:35 PM
