Need help!!!!!!
Need some real help geting swirls and haziing from my car.Its a metalic blue chrysler 300.when I bought it there was a lot of swirls on the car.I hand washed it then used a heavy compound and low speed on a makita 9227.Thought I got them all of but alot are still there! What is the beast way to correct this and what products should be used? I want my car looking wet as possiable. Can someone PLEASE HELP ME.
Re: Need help!!!!!!
heavy compound? what kind of heavy compound? what pads did you use on your machine explain your process.
Super Moderator
Re: Need help!!!!!!
Yes we definately need more info, pictures would be awesome if you have some.
Re: Need help!!!!!!
call Ed ... he kept Meghans 300 in tip top shape. Oh Ed ....
Re: Need help!!!!!!
After washing the car I dried it with a shamie.I used a heavy compound that was for 1200 grit scratches and heavy swirls.I used a yellow #1 cuting foam pad at very low speed no higher then 1500.A lot came of but looking at it in the right light u can still see alot to be fixed.what should be done and used to fix these problems?I can't seem to get them off.Not sure how to do this.
