Results 1 to 8 of 8
    May 2008
    199
    How to avoid dry buffing
    If I am applying wax (SS-II or XMT 180) via buffer do I use a polishing pad conditioner or crystal mist to pad before applying the wax?
    I know that this is a dumb question, please bear with me while I learn.
    Jul 2008
    Cary, Illinois
    43
    Re: How to avoid dry buffing
    You just need to learn how the polish breaks down. What buffer are you using to apply it with?
    1990 AWD Eagle Talon
    11 second E85 powered 16g
    Feb 2008
    76
    Sqeeky,
    The wax should lube the pad well enough without a spritz. If you want to however, any QD would work. Polishes however do need a little help at the start....
    May 2008
    199
    Okay thanks, I'm using a cyclo, putting a little bit on the 2 pads and doing one panel at a time. I just wanted to be sure I am doing it correctly.
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    no need to dampen pad with waxes, just use a finishing pad. Light coats are best.
    Jul 2008
    Cary, Illinois
    43
    You use to much and it acts to much like a lube not alowing the polish to break down and do its job.
    Feb 2008
    76
    TSI,
    He was asking about applying a wax, not a polish.
    Super Member Rsurfer's Avatar
    Jan 2007
    14,100
    Quote Originally Posted by killrwheels@autogeek View Post
  1. Best Practice - Avoid buffing on top of body lines and edges
    Last Post: 04-15-2020, 10:09 AM
  2. Which ones MUST you avoid application in the sun
    By ccm in forum Auto Detailing 101
    Last Post: 09-30-2015, 01:23 PM
  3. how to avoid wax residue
    By Abram86 in forum Tricks, Tips and Techniques
    Last Post: 03-03-2014, 07:39 PM
  4. Should I Avoid a Job?
    By garyg7133 in forum Auto Detailing 101
    Last Post: 05-28-2013, 07:59 AM
  5. Avoid scratching when using a QD?
    Last Post: 01-14-2010, 08:32 AM
