Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Aug 2010
    New Jersey
    15,347
    Re: Do you find OE wheels scratch chip easily.....Clear Coat Mumblings
    I would surmise that the opaque paint has primer under it which gives some corrosion protection to the substrate, where the clear sections obviously don't have that.
    Aug 2013
    St Louis metro (Illinois)
    5,855
    I think there is something about the clear not bonding as well to the diamond cut areas as it does to the painted areas.
    On our Toyota's wheels it had a combination of diamond cut facing surfaces and the areas on the sides of the spokes and the area between the spokes was painted. The painted areas remained pristine while the diamond cut areas were in pretty sad shape because the clear had chipped, bubbled, and pretty much failed across any diamond cut surface.
  3. #13
    Aug 2010
    New Jersey
    15,347
    Of course, that's why you use primer when you paint.
  4. Thanks Desertnate thanked for this post
  5. #14
    May 2007
    682
    Sometimes I've observant , sometimes I'm not.....
    Interesting observation on a freshly powder coated wheel
    I was washing the wheel down to get rid of the tire goop used when mounting, etc - and the entire wheel (just fresh out of the oven)......hasn't seen any road use, etc - it was super hydrophobic. Water was beading and sheeting all over the entire wheel. I cannot recall ever seeing this but for the next set of wheels, I plan to observe and see if I duplicate this same effect.
  6. #15
    Aug 2010
    New Jersey
    15,347
    It's been noted many times on the forums that fresh paint beads, I don't see any reason why fresh powdercoat wouldn't do the same.
  7. #16
    May 2007
    682
    Fresh paint + Beading was not on my ####
  1. Scratch Resistant Clear Coat
    By PDC in forum Ask your detailing questions!
    Last Post: 12-27-2021, 07:35 AM
  2. Clear Coat Wheels
    By Willbeen in forum Products Guides
    Last Post: 03-26-2019, 09:36 AM
  3. Rock Chip Repair - Clear Coat?
    By crxman2010 in forum Auto Detailing 101
    Last Post: 07-04-2014, 10:17 AM
  4. Replies: 0
    Last Post: 01-03-2014, 08:56 PM
  5. Scratch resistant clear coat polishing
    By faisal in forum Ask your detailing questions!
    Last Post: 08-31-2012, 04:19 PM
Members who have read this thread: 22
