Page 1 of 7 1234567 LastLast
Results 1 to 10 of 62
    May 2007
    679
    Current Best Hose Nozzle of Choice
    I've been using the Bon Air Hose Nozzles since its inception.
    When it break, I grab another one out of my stash
    I had 2 remaining....grabbed one today, which leaves me with one backup......
    What normally breaks it the center piece...it's plastic.
    I went to use it today and it flew right out......
    I don't believe I opened it the last time I used it - dunno...maybe water froze, it cracked . Maybe....
    This is the weak part as this is the part that always breaks....so I generally do *open* it after every use during the winter
    Anyhow, going to need to replenish and have at least 2 more in the backup[ stash one day.
    What's your (hose nozzle) of choice.
    Aug 2013
    St Louis metro (Illinois)
    5,829
    Re: Current Best Hose Nozzle of Choice
    Nothing fancy. I just get a metal one with the multiple different spray types from my farm supply or hardware store. I didn't always insist on the metal ones until I broke a couple plastic ones at really inconvenient times.
    For several years I used a fireman's style nozzle. I may pick one of those up this Spring.
  3. Likes Sleper liked this post
  4. #3
    Sep 2020
    Eastern PA
    1,807
    I'm in the market. Mine started leaking so I tossed it. It was an Orbit from Lowe's.
  5. Likes Eldorado2k liked this post
  6. #4
    Aug 2010
    New Jersey
    15,258
    I got one of these that I liked a lot--oddly I've only used it for the garden so far: Amazon.com
    But it's not like the fireman's nozzle the OP is talking about.
  7. #5
    Aug 2022
    Dana Point CA
    1,327
    [I]'m pretty sure this is mine.https://www.obsessedgarage.com/produ...fafb312c&_ss=rRobot or human?
    Attached Thumbnails Attached Thumbnails Current Best Hose Nozzle of Choice-img_9034-jpg
  8. #6
    Super Member SNP209's Avatar
    Sep 2016
    737
    I have become partial to this Gilmour model. The swivel is a plus and the flood setting comes in handy for flood rinsing panels which leaves very minimal residual water behind.
    Amazon.com
  9. #7
    Aug 2013
    5,829
    Quote Originally Posted by SNP209 View Post
    Amazon.com
    I do miss a good flood setting. Very few seem to have it any more. Not only is it great for flood risning a car, but I like it when watering our flower and tomato pots too.
  10. #8
    May 2007
    679
    MisterSnoop -
    I've always had a shutoff control right off the hose end with a fire nozzle. Not a trigger style.
    Mainly for a few reasons -
    I generally have set spray on the nozzle on the nozzle type I use. To close it, you need to *turn the thing to close to stop the flow*
    The shutoff let's me achieve the same without changing the nozzle pattern
    Going to post #7. Same thing. I generally use a 36 extension and a 24" looped angle head with a -rainhead- on it for the overhand planters and such. Dramn Red Head or Dramm Yellow Head. The red head has like 1000 holes in it.....it's a very soft pattern especially for the delicate petals on the Summer Annuals
    They do wear out semi quick as the body is plastic with a metal front sieve on it. What generally happens is the front *round* which get's dropped, put on the floor, UV, etc....it cracks or breaks iff and then a smidge of waters starts coming out of it once broken. So either you continue to use it and get a bit of overspray........or you replace it.
  11. #9
    Aug 2010
    New Jersey
    15,258
    Oh no, don't get me talking about tomatoes!
  12. #10
    Nov 2015
    Los Angeles, California
    13,789
    I love this topic. Also, pictures would be nice when mentioning your favorite hose nozzle.
    I personally use the same Orbit nozzle posted by MisterSnoop. That thing is great and built to last. The only downside is the on/off lever tends to get stiff with age, but when it’s new it just doesn’t get any better IMO.
    For wheels, I switch to a classic brass nozzle because it provides a strong stream that’s a bit wider than the jet setting on the nozzle.
    And for the final rinse I switch to this hose piece to provide a smooth sheeting rinse.
  13. Likes 2FORDS liked this post
  1. Hose nozzle
    Last Post: 03-16-2020, 02:34 PM
  2. Replies: 13
    Last Post: 10-13-2013, 06:24 PM
  3. Hose Nozzle
    By shrtbull in forum Auto Detailing 101
    Last Post: 03-02-2012, 10:27 PM
  4. Low Pressure/Weak Flow From Spigot/Hose. Cheap Fix? Fire Hose Nozzle?
    By Alpham911 in forum Ask your detailing questions!
    Last Post: 08-15-2011, 11:31 PM
  5. Best Hose Nozzle
    By BlackCoupe in forum Auto Detailing 101
    Last Post: 04-10-2007, 06:15 PM
Members who have read this thread: 80
