Results 11 to 20 of 37
    Aug 2022
    Dana Point CA
    1,327
    Re: Ceramic Coating - Maintenance Polish ?
    Ceramic Coating - Maintenance Polish ?-qa-jpg
    I would use the $550 towards having it re coated!
    She's lasted her claimed lifespan.
  2. Likes Eric7810, vaca22, Optimus Grime liked this post
  3. #12
    Feb 2021
    That's why I was asking what the coating was, if it was some super coating that can be polished.
    It's CQuartz Finest Reserve.
    This is what's described under their ceramic maintenance polish:
    The perfect way to maintain or enhance your ceramic coated vehicle. We start with a thorough cleaning and decontamination of your vehicleÂ’s paint to remove stubborn iron deposits from brake dust, road tar and environmental contaminants. Next we perform a professional polish using Essence Plus. Essence Plus is the first non-abrasive solution to partially repair fine swirls, increasing gloss with itÂ’s distinct blend of ceramic coat repair agents, high gloss quartz resins and hydrophobic nanoparticles. This is a great once a year service on ceramic coated vehicles. *We can also perform this service on non ceramic coated vehicles if you are prepping a car for sale or long term protection is not necessary.
    Includes:
    Foam Bath Pre-Soak
    Gentle 2 Bucket Hand Wash
    Clean Wheels
    Clean Door Jambs
    Paint Decontamination w/Iron Remover
    Paint Decontamination w/Tar Remover
    Mask Trim
    Gloss Enhancement Polish w/Essence Plus
    Polish Exhaust Tips
    Tire Dressing
    Courtesy Vacuum and Windows
  4. #13
    Feb 2021
    He did state he takes in for Decontamination washes 1-2 times a year.
    Being garaged and less than 3k miles seems short lived if it was supposed to get 5 years but a lot of “5 year” coatings from pro’s mean you need to do maintenance and that sometimes include top ups
    I would definitely ask what was done in the Decon wash. I would also look into Labocosmetica 3ph Wash. it is triple wash starting with an Alklaine, then an Acid then a PH 7 wash.
    If he’s using this kind of decon wash then I would ask questions about this “ceramic maintenance polish”
    Every coating I know of is removed by polishing so my guess is quick decon wash, clay, light polish and then a new layer of the coating.
    If this is needed I would ask for a deal for it failing with it being garaged and 3k miles per year….
    Thanks for the info!
    This is what's under the Ceramic Maintenance Polish:
    The perfect way to maintain or enhance your ceramic coated vehicle. We start with a thorough cleaning and decontamination of your vehicle’s paint to remove stubborn iron deposits from brake dust, road tar and environmental contaminants. Next we perform a professional polish using Essence Plus. Essence Plus is the first non-abrasive solution to partially repair fine swirls, increasing gloss with it’s distinct blend of ceramic coat repair agents, high gloss quartz resins and hydrophobic nanoparticles. This is a great once a year service on ceramic coated vehicles. *We can also perform this service on non ceramic coated vehicles if you are prepping a car for sale or long term protection is not necessary.
    Includes:
    Foam Bath Pre-Soak
    Clean Wheels
    Clean Door Jambs
    Mask Trim
    Polish Exhaust Tips
    Tire Dressing
    The decon wash I've been getting has this info on their website:
    Decontamination Ceramic Wash is the preferred and recommended maintenance service for ceramic coated vehicles. Using products specially formulated for ceramic coatings allowing for a non abrasive removal of light pitch and road tar. Recommended every 2-3 months.
    Pre-Foam Bath
    Gentle two bucket hand wash using CarPro Reset
    CarPro Iron X Decontamination
    CarPro Tar X Decontamination
    CarPro Hydro 2 Sealant
    Clean Wheels
    Dry Paint
    Dry Door Jambs
    Tire Dressing
  5. #14
    Dec 2018
    7,210
    There’s a small chance the hydro 2 could be “clogging” your coating. There decon wash seems to not attack the road film. Nothing they stated would do that.
    I would personally before anything else order Labocosmetica 3 PH wash… watch the video and do it. I would also use iron x.
    I don’t think Essence plus will revitalize your coating. If you read reviews it’s not a good beader but my thinking is that even though not mentioned the will be topping your coating.
    Also to be honest I would not pay for there decon wash. Only thing there doing extra is treating your car with iron X and Tar X. You could do that in your normal wash.
    Also after reading polish description it says nothing about bringing back beading. Says will fix swirls and restore gloss. I’ve read that it will not remove coating so maybe it will bring back….. still try a 3 ph wash first.
    $550 to restore…. How much ch did it cost to coat?
  6. #15
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by TBrio View Post
    I had ceramic coating done on my car 3 years ago. It started failing on the bottom half of the car and back (not sure if the back is due to airflow when driving) a year and a half after it was done. It's totally my fault for not notifying the installer at the time these issues arose, but due to some personal reasons, the ceramic coating was the least of my concerns at that time! I called the installer yesterday who recommended bringing it in for a ceramic maintenance polish for $550 (for a Porsche Cayenne).
    I take good care of my car - it's garaged, only ever hand washed, it's 4 years old and only has 11,000 miles, is taken in for decontamination wash 1-2x/year, etc. However, since I live in the Seattle are, it gets rained on A LOT and I'll admit that I'm not the best at cleaning it and it does sometimes sit for a month or two with the dirt from the rainy roads.
    Should the ceramic coating have lasted longer? Or, can the timeframe be affected by letting the dirt sit on it?
    Will the maintenance polish make a difference?
    I hate to put additional $ into the coating if it's not going to last another 2 years (installer said the coating I purchased should last around 5 years total). I'm also hoping going to the original installer will allow him the chance to see where the coating is failing and perhaps fix the issue beyond just doing the polish if he thinks it is failing for other reasons.
    This is my first experience doing a coating, so just wanted to get your experience and feedback on this situation.
    Not necessarily for this instance, but I think it's a mistake when detailers and manufacturers use primarily years to describe longevity. Miles matter more than years as coatings tend to wear down from abrasion as well as exposure to the elements. I also don't buy into them lasting more than 2-3 years. I market no more than 3 years or 36k when I work with people on my offerings. There are lots of variables involved, so i won't digress more here.
    I'm also NOT a fan AT ALL of CarPro Essence Plus. I've used it and tested it and feel it's complete garbage. Any use of a polisher over a coating, even with that product, isn't going to yield a longer life. Even when applied by hand, that product never produced anywhere near acceptable results for me. Again, my opinion and experience with it, having tested it on my own vehicle back in the day. If they used that within their process once or twice per year on yours, then I'm not at all surprised as your results.
    To answer your question, yes, it should have lasted longer, and in my experience, it would have if all that was done was a basic wash and decon. Rain and road debris will degrade the sides of the course as I've noted above, it's abrasion. However, in 11k miles.....no. Rain and dirt being left on for 1-2 months....yeah, not great, but all that's really going to do is bond a road film and some ferrous particles to the surface/coating. Yes, over time, if left, it will degrade the coating a bit. Those ferrous particles that cause rail dust spots essentially degrade and break through the coating. I have a friend, Model Y, who is white and showing signs of that, and I coated it last year. He runs it as a daily; it's winter here, and he only does touchless washes. I have no doubt a nice spring wash and decon will bring back 90% but I'll have re-top it with GYEON's CanCoat EVO to help account for those areas that have degraded due to this exposure.
    In the end, to keep it short, work back with the installer to simply make it right. As a detailer, I would 100% do it when this comes up. I have no problem doing so. It's very quick and won't need the involvement of a polisher in most cases. For you, I would take that and live with it day forward for the next 1-2 years, and when you have it re-done, simply understand the above and perhaps just keep it more clean more often and skip any "polish" with Essence Plus. Again, YMMV, but I'm not a fan of that product.
    2023
  7. Thanks opie thanked for this post
  8. #16
    Super Member Optimus Grime's Avatar
    Feb 2023
    Concord, NC
    333
    Quote Originally Posted by TTQ B4U View Post
    I’ve never used Essence but it doesn’t jive right with me either. If it’s abrasive enough to remove even light scratching, it’s abrasive enough to remove some of the coating. It sounds like a light polish that leaves behind a ceramic sealant which really makes it no more than a ceramic AIO.
    I’m curious as to the owner’s maintenance routine and what products are being used. I know that he said he only hand washes it but there are a thousand different ways to wash by hand and most of them aren’t desirable. I ask all of my customers to come back after two weeks to inspect the coating and we’ll wash it together. I’ll show how to do a proper wash and show exactly what products should be used to maintain the coating and send customers with a “gift” basket to get them started. I think a lot of coating installers need to do a better job of how to maintain a coating.
  9. #17
    Aug 2010
    New Jersey
    15,287
    TBrio, I was looking at some previous threads where you have stated you are in the Seattle area; we have some members in that area who could perhaps help you get more comfortable or improve the efficiency of your wash techniques, but you are also local to the Griot's Garage headquarters in Tacoma.
    A lot of members use their products, and they have events at their facilities: Events Calendar
    The "Caffeine & Gasoline" may be a good way to talk to other people who have the same goals. They also have a "free car care school": Caffeine & Gasoline(R)
    Although it's a lot easier to learn things online than it was 20 years ago when there were no videos and barely any pictures, sometimes in-person learning can be very helpful. Sometimes a few tips and tricks can get you a better, faster (wash) result, which in turn makes it more enjoyable and something you want to do more often.
    Griot's Garage products are available here in the Autogeek store.
  10. Likes Coatingsarecrack liked this post
  11. #18
    Aug 2013
    St Louis metro (Illinois)
    5,835
    I've found exposure to the environment really had a bigger effect on coating life than miles driven. I coat both my car and the wife's. She drives nearly 30K miles a year and I drive around 9K miles. However, both of our cars are exposed to the elements about the the same amount of time overall; mine sits in parking lots at work or at the airport while her's is in constant motion. In both cases the coating will last roughly three years despite a vast difference in mileage driven.
    Totally agree. I've seen CQUK go longer than 3 years, but at that point the water behavior isn't consistant across the whole vehicle. Horizontal surfaces like the roof and hood start to degrade at that point and water sheeting starts to slow dramatically, even if the beading is pretty good. Also, three years is a long time for the life of a daily driver. At that point the overall appearance of the vehicle starts to dull simply from wear on the coating, occasional randoms stratches and minor swirling that happens no matter how careful we might be.
  12. #19
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    2,006
    Totally agree. I've seen CQUK go longer than 3 years, but at that point the water behavior isn't consistent across the whole vehicle. Horizontal surfaces like the roof and hood start to degrade at that point and water sheeting starts to slow dramatically, even if the beading is pretty good. Also, three years is a long time for the life of a daily driver. At that point the overall appearance of the vehicle starts to dull simply from wear on the coating, occasional randoms stratches and minor swirling that happens no matter how careful we might be.
    I think a lot of that difference could be somewhat climate related as well. While here in the NE (or maybe it has to do with the strengths/weaknesses of individual coatings) I found that leaving cars sitting outside in the elements 24/7, 365 days a year had little effect on overall coating longevity/performance...it was the miles driven that killed overall effectiveness. I used to correspond frequently with a coating junkie who lived in Phoenix and he noted somewhat of the opposite effect...exposure when stationary seemed to diminish his performance more than a vehicle that was driven more miles but under cover each day/night. It corresponded to where the coating bought the farm as well. Was always vertical panels for me, horizontal for them.
    The ultimate YMMV scenario!
  13. #20
    Super Member Eric7810's Avatar
    Mar 2019
    330
    This is a prime example of why I never promise a life span to anybody who comes in for a coating.. anything that lasts more than two years on a car is truly phenomenal.
    If I coated your vehicle in 2020 and you’re reaching out disappointed in its longevity then I dropped the ball communicating and setting expectations, whether daily driven or not.
  14. Likes DanaDetailingPros liked this post
  1. Questions on pro ceramic coating and maintenance
    By BrightShine in forum Auto Detailing 101
    Last Post: 07-23-2020, 02:59 PM
  2. Gtecniq Ceramic Coating Maintenance?
    By RMarkJr in forum Auto Detailing 101
    Last Post: 04-30-2019, 11:03 PM
  3. Replies: 7
    Last Post: 09-30-2018, 08:54 PM
  4. Replies: 8
    Last Post: 03-24-2018, 11:39 PM
  5. Using a polish on ceramic coating?
    By HAMBO in forum Auto Detailing 101
    Last Post: 06-21-2017, 08:31 PM
Members who have read this thread: 52
