Results 1 to 6 of 6
    Aug 2018
    107
    how should I remove the gas stain
    2023 Camry Ice Edge color
    I filled up gas about a week ago. Most likely, the attendant didn't close the cap properly and the gas leaked. I started smelling gas yesterday, but could not figure out. Tightened the cap and I thought it is fixed.
    Upon closer inspection, I noticed the gas spilled out and the stain.
    I wiped the area with soap and tried cleaning with Klasse AIO (which is suggested in earlier posts) but was unsuccessful.
    Any ideas on how I can clean the stain.
    Before I tried cleaning with Klasse AIO
    After Klasse AIO
    Thanks in advance.
    Aug 2010
    New Jersey
    15,173
    Re: how should I remove the gas stain
    "The attendant"...sounds like a Jersey problem. KAIO isn't very aggressive, but on the other hand, if that's penetrated into the clear, there may not be a lot you can do about it. You used the KAIO by hand? Do you have a machine? What other polishes do you have?
  3. Likes opie liked this post
  4. #3
    Aug 2013
    St Louis metro (Illinois)
    5,811
    I wonder if clay bar might be a little more effective than Klasse AIO, which is really a chemical cleaner and not abrasive from what I remember.
    If clay doesn't work, I'd go where the above suggestion is headed and try to polish it out.
  5. #4
    Jan 2015
    Simi Valley, CA
    1,783
    You can try another AIO and see what it does... But I'd probably go to a straight polish since you already tried Klasse. That's really all you can do.
    If the polish doesn't remove the stain, then you're pretty much SOL. Gasoline can permeate the finish and permanently or semi-permanently stain it. If that is the case, just clean and polish as best you can, and then give it some time. I've seen stains like that improve over time... Weeks or months, not hours or days.
  6. #5
    Aug 2018
    107
    Yes, I used KAIO by hand. I don't have machine or any other polishes. Thats above my skill level. I might as well just find a detailer to work on it.
  7. #6
    Nov 2015
    Los Angeles, California
    13,765
    Get some Meguiars Ultimate Compound & microfiber applicator.
  8. Likes PouncingPanzer liked this post
  1. I put IPA on hot paint? How to remove stain?
    By locarno in forum Ask your detailing questions!
    Last Post: 06-28-2021, 08:10 AM
  2. How to remove this stain from the paint
    Last Post: 05-31-2019, 01:10 PM
  3. How would You get Remove this Stain from Dash?
    By Ericsworld in forum Ask your detailing questions!
    Last Post: 02-10-2019, 07:13 AM
  4. Remove this stain
    By nickyd845 in forum Ask your detailing questions!
    Last Post: 08-24-2017, 08:59 PM
  5. How to remove a salt stain
    By Quikor in forum Auto Detailing 101
    Last Post: 03-08-2010, 04:25 PM
Members who have read this thread: 24
