Results 1 to 5 of 5
    Mar 2023
    Gyeon Rim apply in cold weather
    I just purchased a new set of painted and clear coated 4Play wheels. Being in Indiana I also picked up some Gyeon Rim to put on them to protect against road salt. However I didn't realize that the minimum recommended temperature to apply it is around 59F and it's going to be colder than that until spring. Also didn't expect it to smell so strong, the wife would probably have a fit if I did it indoors. This weekend the temperature is supposed to be close to 50F, do you think I can get by at this temp?
    Attached Thumbnails Attached Thumbnails Gyeon Rim apply in cold weather-pxl_20231213_011759364-jpg
    Feb 2012
    Palatine Illinois, USA
    24,564
    Re: Gyeon Rim apply in cold weather
    Just do them in a back room or the basementGyeon Rim apply in cold weather I coated my rims the past 2 "off seasons" and did them upstairs in the living room, let them cure for an entire week and then put them down in basement storageGyeon Rim apply in cold weather
    2022 Elantra N Cyber Gray
    Aug 2013
    St Louis metro (Illinois)
    5,809
    I'm not familiar with Rim, but if it requires any type of flash time, the flashing will be much slower in the cold. If it doesn't require any flash time and is a wipe on/wipe off type product, I'd still be cautious while doing the first wheel. Watch to make sure you are smearing the product while removing. If so, let it sit before removing.
    I'd do a small area of the wheel barrel to get a feel for how the application will go in your weather conditions before doing the whole thing and getting into potential problems.
    May 2020
    90
    I'd just apply the coating indoors in a room where you can close the door and put a fan in a window to suck out any fumes.
  5. Thanks Klasse Act thanked for this post
    Likes Klasse Act liked this post
  6. #5
    Mar 2023
    Went ahead and did it indoors. The smell wasn't nearly as bad as I thought it would be. End up putting 2 coats on at about 24 hrs apart. I was expecting the coating to flash but after applying to the entire wheel and waiting a few more minutes the product never flashed. The instructions said to remove immediately so I removed before any flashing occured.
  1. Cold weather ?
    By DogRescuer in forum Auto Detailing 101
    Last Post: 10-10-2013, 07:38 AM
  2. buffing in cold weather.....
    By Rival in forum Wet-Sanding, Cutting & Buffing
    Last Post: 04-11-2013, 04:31 PM
  3. Dumb Question: How cold is too cold to apply?
    By shipkiller in forum Pinnacle Wax
    Last Post: 12-06-2010, 11:35 AM
  4. Help detailing in the cold weather!!!
    By gooch06 in forum Auto Detailing 101
    Last Post: 02-06-2007, 04:11 PM
  5. Cold Weather
    By BILL in forum Auto Detailing 101
    Last Post: 01-22-2007, 11:22 AM
Members who have read this thread: 27
