Results 1 to 5 of 5
    Oct 2015
    Salt brine dissolving/neutralizing options for those that can only do rinseless washes
    My main concern is the undercarriage. Does anyone have any suggestions of products that can be applied with a spray bottle or pump sprayer, doesn't require agitation, and doesn't only come in commercial/industrial quantities?
    I don't have access to a hose or foam cannon so my only options are rinseless washes and the local coin-op. Even using the coin-op sprayer, the brine solution seems to cling to my coated paint, I can only image how little effect the sprayer had on the undercarriage.
    I see lots of recommendations for Bilt Hamber Touchless, but this looks hard to find in the US. If I can find it, would it be effective to apply to the undercarriage with a spray bottle and rinse off at a coin-op? I've also seen recommendations for Eastwood Road Salt Neutralizer, but I can only find gallon concentrates, which is probably way more than I need. I couldn't find any salt specific products on Autogeek.
    Aug 2010
    New Jersey
    15,274
    Re: Salt brine dissolving/neutralizing options for those that can only do rinseless washes
    How are you going to spray the undercarriage with a spray bottle? Other members will chime in, but the only way I've found to get the film off (the paint) that remains after pressure washing is with a contact wash, in your situation that would be your rinseless.
    Super Member Optimus Grime's Avatar
    Feb 2023
    Concord, NC
    323
    One of the guys from the rag company mentioned that Brake Buster can be used to clean undercarriages. It has corrosion inhibitors that will aid in protecting it from further damage. There’s still the question of how will you spray it on the undercarriage and then how will you wash it. Without some kind of sprayer with a long wand and an undercarriage washer hooked up to a pressure washer I don’t know how you’ll accomplish this.
    Super Member John U's Avatar
    Mar 2006
    Eagan MN & Scottsdale AZ
    665
    You need to apply a coating like Crown in Canada uses that is applied yearly.
    Aug 2020
    922
    The best thing to do is spray off at a coin op after every snow storm.
  6. Likes Jackismydog liked this post
  1. Rinseless wash on vehicle with salt.
    By 68bowtie in forum Ask your detailing questions!
    Last Post: 01-28-2019, 08:25 PM
  2. Salt/Brine/Rust
    By davidc in forum Tricks, Tips and Techniques
    Last Post: 11-24-2013, 11:15 AM
  3. Who here DOES NOT like rinseless washes?
    By Harry Da Hamster in forum Auto Detailing 101
    Last Post: 07-22-2013, 10:52 PM
  4. Rinseless Wash & Road Salt?
    By CoachBuesching in forum Ask your detailing questions!
    Last Post: 03-04-2013, 01:12 PM
  5. Rinseless Washes, Which one?
    By hondajake in forum Auto Detailing 101
    Last Post: 09-04-2008, 08:29 PM
Members who have read this thread: 37
