Results 1 to 5 of 5
    Regular Member waterman's Avatar
    Aug 2016
    Schaumburg, il
    198
    Flex pxe vs griots g8
    Hello,
    I currently have Griots g8. I like it but it stalls very easily. I was wondering if the Flex pxe has more power then the Griots. I’m going to be doing several waverunners and need something with a little more power. I like the idea of cordless but if there isn’t much more power I will stick with the Griots.
    Thank you
    Dec 2018
    7,179
    Re: Flex pxe vs griots g8
    Quote Originally Posted by waterman View Post
    Hello,
    Thank you
    It has a rotary mode which won’t stall at all. The g8 has been known to stall and I believe it’s why griots came out with th g13
  3. Likes DanaDetailingPros liked this post
  4. #3
    Super Member John U's Avatar
    Mar 2006
    Eagan MN & Scottsdale AZ
    665
    Happy with mine. I was using a 3" cheap pad once that did not "spin" nicely on the surface. I swapped it for a higher quality pad and it was issue free.
  5. #4
    Super Member VISITOR's Avatar
    May 2007
    9,730
    try using thinner and/or smaller pads with the G8. the flex pxe is cordless (battery operated) and there's no inverter (available at the moment) to plug & play which means you will cycling batteries and wouldn't be ideal on what you are working on...
    i am the jump starter.
  6. #5
    Dec 2018
    7,179
    Maybe look at a true 3” cordless in the HLR75. Detailers Domain is having 25% off Rupes. Pull it up and have Autogeek price match it if it’s still available.
  1. Griots or Flex Input
    By Dmb5450 in forum Auto Detailing 101
    Last Post: 03-20-2015, 09:00 PM
  2. Griots DA or the flex
    By zach.rowe1 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 10-04-2013, 02:54 PM
  3. Griots vs Flex
    By iMuf in forum Auto Detailing 101
    Last Post: 06-08-2013, 07:23 PM
  4. Is flex 3401 better then the griots da.
    By 68bowtie in forum Auto Detailing 101
    Last Post: 08-10-2012, 01:59 PM
  5. What do I want a Flex or a Griots da ?
    By Pontiacfan in forum Ask your detailing questions!
    Last Post: 05-16-2011, 11:23 AM
Members who have read this thread: 33
