Here’s my way of restoring headlights
I clean first with plastic cleaner like Meguiar’s or PlastX.
Then I tape around the lens.
I wet sand to remove the old coating. I start with 500 grit because these are really rough. I use 1000, 2000, 3000 and 4000 grit sandpaper hook and loop on a buffer.
After all the coating is removed (when you see the slurry is clear), I polish with an orange pad and compound followed by a white pad and polish. I clean the polish off with Chemical Guys WipeOut. Then I finish with 2 coats of Meguiar’s Headlight Coating
Acura Headlight Restoration - YouTube
About 1 hour of time, less than $5 of product, $100 cha ching.
Kirk Harrod's Mobile Detailing, Frankfort, KY
Official Detailer of Camarofest 8 & 9
No one has detailed more Camaros.
Re: Here’s my way of restoring headlights
Not speaking on the results in the video… But have you ever noticed how it always somehow looks worse after applying the 2nd coat? Happens every single time. I’ve moved away from doing 2 coats. I go 1 heavy coat and that’s it. Better results. Better final look too.
Just my 2 cents.
Just my 2 cents.
I do the first coat very light and the second coat according to the directions on the can. I can see what you're saying. It can get orange peel if you spray it too thick.
If I lived in a major city, I would get a truck, wrap it with Headlight Restoration all over it, and just do headlights.
Not only that but the clarity suffers. The orangepeel is rarely a problem as the heavier you spray tends to be the better as far as that and I’m a heavy sprayer/user of all products. Plus it helps to start on top and finish at the bottom and let it even itself out. I’m sure you know how it works. It’s a nice product for what it is. Smells good too even though it’s not ideal to be smelling it.
If it needs to be perfect, the spar urethane method is better (once you master the technique.) If it just a regular vehicle, I think the Meguiar's Headlight Coating is fine.
I find it a hard service to bank my promise to… Alot of variables as far as some headlights aren’t very cooperative and the protection/longevity is also hard to give a hard promise to the point where I personally couldn’t hang my reputation on while charging top dollar for.
The only way I would do it with full confidence is if I was applying a UV PPF that was basically guaranteed to outlast. Now we’re talkin.
Do you cover the front end of the vehicle when you spray it? Going all out and taping a drop cloth over the hood & bumper is a pita that I sometimes hate to do. Especially since I’m usually doing it as part of the detail and not a separate dedicated thing I charge for. That’s a big difference for sure.
I use drop cloths and magnets. Every vehicle that I perform this service for are at the end of life. Most people just want to be able to see better at night. I explain that some won't be perfect, but most will be much much better. In my experience, my headlight coatings outlast the vehicle.
By Gav'sPurpleZ in forum Show N' Shine
Last Post: 05-31-2017, 09:18 AM
By dc52nv in forum Auto Detailing 101
Last Post: 03-04-2014, 08:12 PM
By davidc11291 in forum Auto Detailing 101
Last Post: 04-20-2012, 01:03 PM
Last Post: 04-12-2012, 09:27 PM
By Al Dente in forum Auto Detailing 101
Last Post: 11-03-2006, 02:55 PM
Members who have read this thread: 39
- ollever,
- msharpe785,
- Optimus Grime,
- hooked,
- 98CayenneTA,
- Thunderchicken,
- briarpatch,
- barryscott,
- DanaDetailingPros,
- craft_lawrence,
- DFB,
- Jackismydog,
- Desertnate,
- John U,
- SNP209,
- SJP4379,
- hotrodn,
- PA DETAILER,
- vaca22,
- oneheadlite,
- KirkH,
- Tbonem3,
- Azure,
- joebruin77,
- Rsurfer,
- 02whitetundra,
- Setec Astronomy,
- PaulMys,
- dbeng,
- Tasmania,
- waddell64,
- bill walsh,
- D.BRITT,
- grovlet,
- mc2hill,
- RT66Detail,
- Dynoguy,
- PeteT19640,
- Odrapnew
