Re: Suggestions on a cheaper spray and hose off sealant?
Originally Posted by
evo77
^^^THIS
Nothing is cheaper than the Armor All Ceramic. N O T H I N G
End/thread
Mic drop. You’re right. Nothing can touch it especially for that price.
Thank you for the tips.
Thanks guys. Cheap and looks good!
Nano skin super charger $6-7 dollars for 16oz RTU bottle.
If using a lot you can buy a gallon for $120 that’s concentrated 100:1. If i math right that will make 100 gallons. $1.2 a gallon?
Just will have enough to do every car in your state once…
3D bead it up can be used the same way as wet coat is is super cheap by the gallon.
Dr Oldz
You can spray it on and then hose it off?
MrOneEyedBoh
Yes. Also a great drying aid.
Eldorado2k
from watching youtube videos, all the ones that Ive watched say that I have to agitate it. I guess if Im going to do that, I mind as well just wash with soap and then use one of the spray and rinse sealants like Wetcoat etc.
MrOneEyedBoh
Ignore all the YT videos. No one (from what I've seen) is using Armor All Ceramic *concentrated* in a spray bottle.
See my post HERE for my tips on how to use this product.
In a nutshell, spray >let dwell 15 seconds >rinse. (keep out of direct sunlight)
evo77
See my post
If we’re only getting a few good weeks of beading doesn’t it make sense to use wet coat or the like. That will provide longer beading
MrOneEyedBoh
No. It doesn't make sense to spend more money on Wetcoat or anything else is the same category. And when I said Armor All Ceramic lasts "a few good weeks" that was an estimation as I have never officially recorded how long it actually lasts. It could be a month or longer. Since I always re-apply at every wash, it continues indefinitely. You get what I'm saying? Longevity doesn't matter with this type of product. Its SO EASY to apply, why not reapply every time you wash? Its literally spray and rinse off. If you use it every wash or every other wash you'll continue infinite protection as long as you keep re-applying it.
Wetcoat on AMZ is 1.36 per oz (17 oz bottle) vs Armor All at Walmart is 23.9c per oz (50 oz bottle). Its not even close in price. And I've used Wetcoat before. There is nothing magical about their formulation. AA Ceramic does the same thing for cheaper.
Just go and buy it at Walmart and try it for yourself. Then report back.
