Re: Do you still use a sealant?
Cosmic water behavior is really nice. On par with Can Coat and other coatings.
PolishAngel Cosmic Spritz and PolishAngel SuperSport | Water Behavior - YouTube
Originally Posted by
CleanIT
This is just Spritz? Did you use the primer at all? As usual for PA, very impressive and it looks great too!
I'm assuming not the coating underneath either? I've got the system to put on the wife's vehicle but had to get brakes, new tires and an alignment completed and now deciding if I want to crank it all out in this 96 degree heat this weekend or not.
Sent from my SM-F936U1 using Tapatalk
Uncbrs
I think it’s just Spritz bc I’ve seen other videos that looked the same.
CleanIT
Op in video says he only uses it on his car which is coated in the comments. Says he’ll have to try as standalone to see.
I do get those type results for 3-4 weeks. Still great after but just not as “coating like”
Post Thanks / Like - 2 Thanks, 2 Likes, 0 Dislikes
Coatingsarecrack
That was the nice thing about Can Coat. Went on like a sealant but held up for a year with high level beading. Of course, you can get that with a sealant but you just need to apply it more frequently, which is what some like to do.
I feel that the sealant on top of CanCoat resulted in more gloss than a sealant alone plus you had the benefit of the coating. I had CanCoat on my car for 15 months that was topped and maintained. It was still beading like day one when I polished it off.
Why did I remove it? I wanted to put on Pur and I’m not too bright.
Mind you I am pleased with Pur but I was very pleased with CC.
Sent from my iPad using Autogeekonline mobile app
