Re: Who here uses Solution Finish?
opie liked this post
Originally Posted by
craigdt
I've got a bottle I need to use.
I tried cleaning my plastic trim 100 different ways and still can't get all the white (wax? Polish?) residue off before using the Solution Finish
I've tried:
Griots Rubber prep
Carpro Eraser
Optimum Power Clean full strength + drill brush
Not sure what else I can try...
Not all plastic trim is created equal. Sometimes no amount of cleaning will get it “ideal” as far as the prep. Sometimes it is prepped even though it doesn’t quite look totally prepped, but it is.
Eldorado2k
Yes.
And Solution Finish is a dye. It hides a lot of imperfections.
PaulMys
Channeling my inner PaulMys
opie
Channel this, makeup boy...........
PaulMys
Yes.
Many believe that SF is a dye and it's not. SF is refined graphite.
Rsurfer
I stand corrected, Ron.
Could you please crack me on the knuckles with a steel ruler??
craigdt
I've tried:
Griots Rubber prep
Carpro Eraser
Sometimes old trim just chalky. With what you’ve tried I don’t think nothing else probably will.
Only thing I can think maybe to try and if they don’t work still nice products to have in arsenal
Blackfire Wax remover
Bilt Hamber Surfex
craigdt
I've tried:
Griots Rubber prep
Carpro Eraser
The wax residue will disappear when you apply SF. Some plastics will reject it all together.
