Results 11 to 20 of 21
    Regular Member Brrr's Avatar
    Jun 2022
    133
    Re: Alright boys, let’s get a plan together for my late dads Jeep Cherokee.
    Quote Originally Posted by opie View Post
    You have 3d speed and 3d one backwards. 3d speed is an "aio" cleans,polishes,and protects, as it contains poxy.
    3d one is a compound/polish. Which is pad dependant so that determins how much cut you get. Ive never used 3d one and probly never will. Many ppl on here like it.
    And personally i would not worry about water when cleaning out the engine bay with that bad gasket. I would want that clean b4 i preform the repair anyway.
    Yeah, I realized that now. For some reason I thought it was the other way around. I even ordered Poxy when I ordered Speed to put over it lol
    Alright gentlemen, I appreciate all the info. Will start the process Friday if I don’t get rained out and will post updates here.
    Again, appreciate the info and wisdom.
    2021 Ford F-150 XL STX 5.0 Coyote
    2016 Ford Mustang 2.3 Ecoboost
    2010 GMC Acadia 3.6
  2. Likes Uncbrs, opie liked this post
  3. #12
    Dec 2018
    7,255
    Quote Originally Posted by Brrr View Post
    It’s only got 150k on the odometer. Needs some work though. Alternator, shocks, u joints, floor pans just to name a few.
    Agreed with a good wash. Look into 3ph Wash and if you don’t mind spending a little more look into Labocosmetica 3ph Wash.
    Have some small brushes (including soft tooth brushes to get all books and crannies.
    I would use a iron remover and tar remover first. Then do baggie test to decide if your gonna need fine, medium or aggressive claying.
    Then I would use griots FCC or CC with the LC flats. To get swirls and scratches. Then hit it with a polishing pad and a polish with perfecting and a polishing pad. Protect with product of your choice.
  4. Likes Brrr liked this post
  5. #13
    Super Member JDGolden's Avatar
    Mar 2013
    Michigan
    1,520
    Sorry to hear about your dad. I look forward to seeing this done. I had a red 96 back in the day.
    I’m also in the camp of wash, clay/decon, and HD Speed.
    2017 Jeep Wrangler Unlimited Rubicon
    1999 Camaro Z28
  6. Likes Brrr, opie liked this post
  7. #14
    Jun 2022
    133
    I get the baggy test, but how does it determine what kind of clay to use? The more it grabs, the more aggressive measures I’ll need?
    Edit: the 3PH soap you’re referring to is that Labocosmetica PURÌFICA?
    2010 GMC Acadia 3.6
  8. #15
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,239
    The rougher the surface feels the more bonded contaiminants are present on the paint.
    Iwould use nothing less than meguiars mild clay, wouldnt hurt to probly use megs agressive clay. Eldo always reccomends that one.
  9. Likes Brrr, Coatingsarecrack liked this post
  10. #16
    Jun 2022
    133
    Any idea what kind of clay bar these are? Probably mild. I looked the box over and couldn’t find any specification.
    2010 GMC Acadia 3.6
  11. #17
    Mar 2021
    Pa
    2,239
    That is a fine clay. You will need to look online or an actual deatiling brick and motar store near you to find mild or aggressive clays
  12. Likes Brrr liked this post
  13. #18
    Dec 2018
    7,255
    It’s Primus (alkaline) followed by Purifica (acid) and then Semper (ph neutral)
    You can try to mix in your own alkaline and ph7 with Purifica but if you need it all I’d stick with the kit.
  14. Likes Brrr liked this post
  15. #19
    Jun 2022
    133
    I did a test run with what I had on hand. I used Speed on the top left of the hood with LC Flat, Bottom right was Griots FCC with a Uro-cell, bottom right was fcc with a LC flat and top right was speed with a Uro cell.
    Looks about the same to me. Definitely needed to do a deep wash on this. The pads I used are lookin rough. If I was worried about getting a better finish, I would really deep clean the Jeep but I’m happy with the results and will probably just go ahead and do the whole Jeep tomorrow.
    I definitely prefer the Uro-Cell over the Flats. The flats feel like they want to “hop” around or bounce. The UC didn’t feel like that at all. The UC’s are a little bigger too.
    Now I’m gonna break out my GR3 mini and see what I can screw up.
    2010 GMC Acadia 3.6
  16. Likes Uncbrs, SNP209, bill walsh, opie liked this post
  17. #20
    Super Member 392hemi's Avatar
    Dec 2016
    438
    Are your pads pulling oxidation?
  1. dried cement on late model Jeep
    By Red Hawk in forum Ask your detailing questions!
    Last Post: 10-05-2018, 07:16 AM
  2. Alright alright alright need some paint correction help
    By Bill1234 in forum Auto Detailing 101
    Last Post: 11-20-2015, 05:13 PM
  3. Jeep Cherokee C Quartz
    By Andrew@ToyMotorsports in forum Hot topics & Frequently Asked Questions
    Last Post: 04-02-2014, 05:10 PM
  4. Dads Jeep needs help
    By RChicago in forum Ask your detailing questions!
    Last Post: 04-10-2012, 10:05 AM
  5. 1992 Jeep Cherokee
    By Nica in forum Show N' Shine
    Last Post: 04-09-2007, 09:10 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
