Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Iron remover
    Feb 2011
    72
    Iron remover
    Is it worth the expense and time to use an iron remover on an older vehicle? I have a 2017 Jeep Grand Cherokee limited with 97k miles.
    Sep 2015
    2,173
    Re: Iron remover
    Quote Originally Posted by capnp72 View Post
    I do not see a reason why not. I have a 2013 Tundra with 121k.....when it gets a full detail, its gets clayed and sprayed with Iron-X.
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Re: Iron remover
    It depends, are you planning to do a full detail? Detailers have been polishing cars for over half a century and there wasn't iron removers back then, but there was rail dust and brake dust. Does that mean they did an incomplete job?
  4. Likes PouncingPanzer liked this post
  5. #4
    Nov 2015
    Los Angeles, California
    13,765
    Re: Iron remover
    IMO the short answer is no, not needed as long as you plan on clay barring the vehicle. The clay will do everything an iron remover will do and more.
    This makes me think, back when products i.e. Iron X 1st came to market, was it mainly described for use on wheels? Or was it marketed for use on paint? I’ve got a hunch it had to be 1 before the other, and if it was wheels than that would explain alot, because most people never get around to claying their wheels, which in turn sort of makes using Iron X to clean your wheels a pretty good idea since how else would you go about removing iron particles and therefore preventing premature deterioration of the clearcoat on your wheels…
    I believe acid based wheel cleaners also help remove iron particles, but alot of people are scared to death to use them, so that wouldn’t work for them.
    My gut tells me that could’ve been the whole reason they decided to make Iron X in the 1st place. What do you guys think?
  6. #5
    Super Member Bill D's Avatar
    Mar 2006
    The First Coast of FL
    2,376
    Re: Iron remover
    I used the Valugard ABC system on a contaminated car before claying—if claying was even necessary ( you can also clay during step B) it’s my understanding this system was the original., even before Iron X,but it remains unpopular because it’s a 3 step system, was never marketed to mainstream detailers, and isn’t straight forward to obtain. I think Valugard is missing the boat by not marketing this system to professional detainers and enthusiasts
    Any way, here’s how the system works:
    How To Remove Industrial Fallout and Rail Dust / Valugard A-B-C Neutralization Procedure - YouTube
  7. #6
    Dec 2018
    7,177
    Re: Iron remover
    If you plan to keep the vehicle for a long while I would personally use Iron remover. Did want hurt and doesn’t mar.
    If your plan on claying I would still use. I’m in the camp the clay would remove all the iron and iron remover would but I want least amount of particles dragged across my paint. Less micro marring and longer clear coat preservation.
    I’m sure clay would remove dirt from paint but that would scratch paint right? I think of it as kinda the same.
  8. Likes Rsurfer liked this post
  9. #7
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,226
    Re: Iron remover
    I like your analogyIron remover
  10. #8
    Mar 2021
    Pa
    2,226
    Re: Iron remover
    I think you make a good point. Look at 3d's iron remover for instance...BDX, i always have seen it more marketed for the wheels
  11. Likes Eldorado2k liked this post
  12. #9
    Feb 2011
    72
    Re: Iron remover
    Yes, I am planning on doing a full detail.
  13. #10
    Nov 2017
    69
    Re: Iron remover
    I clay bared a 21 year old garage kept camry today that had never been detailed its entire life. the paint looked good after washing it, but when I began the clar bar cleanup, the paint was so rough with fallout that I was worried about the clay bar operation scratching the paint futher because of the heavy amount of fallout that the clay was dragging out. Anyway I stopped after the roof and back lid, and ordered some iron remover, since the fallout wasn't coming off easily with the clay - meaning there was lots of trash and it had been stuck in the paint a very very long time. So from this experience, I say for really heavily contaminated paint, I say use an iron remover FIRST, so that the subsequent clay bar procedure will be more productive with less damage during the operation. I suppose if I had a more coarse grade of clay it might have worked better, since a little marring I think is better than whatever amount of scratching created by the clay bar cleaning itself.
  14. Likes DFB, Eric7810 liked this post
  1. Rusted Cast Iron / Iron X / Iron remover
    By Swift in forum Off-Topic
    Last Post: 01-19-2018, 09:23 AM
  2. Mckee's Xtreme Iron Remover vs. Iron X Comparison
    By Jeremy1976 in forum Product Reviews
    Last Post: 02-19-2017, 09:40 PM
  3. Replies: 3
    Last Post: 12-04-2016, 02:41 PM
  4. Replies: 4
    Last Post: 02-15-2013, 05:14 PM
