Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 54
    Super Member MrOneEyedBoh's Avatar
    Mar 2013
    1,186
    Re: Questions on Gyeon CanCoat Evo and its application
    Quote Originally Posted by DFB View Post
    Those towels should be fine. Be sure to demote them after use though.
    I wonder if I can throw them in a strong APC bucket and then wash immediately? Will they be salvage-able?
    Dec 2011
    Pompano Beach, Fl
    1,494
    I stop ruining towels with spray coatings by using a microfiber brick, it works just as well, and then the after wipe with a normal microfiber doesn’t harm the towel. The plastic layer bricks that are above somewhere are the hot ticket.
    On a slightly different subject, I really wish the chemists that come up with these coatings, could do something like the spray blue aerosol that I use to clean my sinks, it comes out blue, and you know it has its effect after it turns white so you can rinse it down. I wish that you could spray on a coating like CanCoat, and have it be slightly chalky or something and then as it wipes down with a microfiber that would disappear. Then you could see if you had any hi spots or spots where you just missed it all together.
    Glen -
  3. #13
    Super Member DFB's Avatar
    Aug 2019
    Australia
    3,212
    Quote Originally Posted by MrOneEyedBoh View Post
    You can, but I don't personally risk it. I generally demote them to the rag pile/oil changes/machine maintenance ect.
  4. Likes BudgetPlan1, Coatingsarecrack liked this post
  5. #14
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,230
    Ive used wipe off coating towels many times, including can coat.
    Pure evo however has left hard spots on my towels. But after i realized that i soaked them right away in towel kleen, washed at a later date. No issues since.
    I bet an apc would serve the same result.
    You just have to like always...inspect your towels after every wash.
  6. #15
    Mar 2013
    1,186
    Whats your thoughts on a wipe between coats? There is going to inevitably have some pollen settling on the paint between the first coat and second coat. Should I just leave it as is and just roll with another coat?
  7. #16
    Mar 2017
    Southeastern PA
    2,480
    Quote Originally Posted by glen e View Post
    Adam's has some coating that reacts to UV light and then you can see if there's a spot you still have to wipe off. I haven't tried it so I can't say how well that really works.
    Bruno Soares
  8. #17
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Only 1 layer is needed. If it’s going to get pollen then wait until the first wash. Pollen is abrasive.
    No harsh chemicals should be used on a fresh layer including a panel wipe.
  9. Likes DFB, MrOneEyedBoh, fly07sti liked this post
  10. #18
    Aug 2022
    Dana Point CA
    1,327
    Stupid question but I also live near you Guz and what does our pollen look like? I have a fresh dark redish dust all over after a day of siting. 3 days. Forgetaboutit!
  11. #19
    Nov 2015
    Los Angeles, California
    13,788
    Quote Originally Posted by DanaDetailingPros View Post
    I’m in LA and I’m not sure if I’ve ever experienced pollen. But I can show you what smog & refineries do to contaminate some paint. Lol.
  12. #20
    Mar 2021
    Pa
    2,230
    But yinz are supossed to be the "green" state...no? With the most strick emissions and all that feel good jazz. Figured the air out there was so clean...i can smell the malarky from the other side of the countryQuestions on Gyeon CanCoat Evo and its applicationQuestions on Gyeon CanCoat Evo and its applicationQuestions on Gyeon CanCoat Evo and its applicationQuestions on Gyeon CanCoat Evo and its application
  1. Gyeon wet coat application questions
    Last Post: 06-26-2021, 02:30 PM
  2. Gyeon CanCoat vs Gyeon Trim
    By Diezel in forum GYEON Car Care Products
    Last Post: 07-09-2020, 02:52 PM
  3. Gyeon cancoat vs cancoat over essence vs Sonax PNS
    Last Post: 04-30-2017, 09:14 PM
  4. Gyeon CanCoat
    Last Post: 03-17-2017, 01:53 PM
  5. Gyeon Mohs and Trim application questions
    By andygold in forum Auto Detailing 101
    Last Post: 01-04-2017, 08:41 AM
Members who have read this thread: 33
