Results 11 to 20 of 27
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    Re: Using snow foam to wash car
    You're such a bogan! ��
  2. Likes Big Dave liked this post
  3. #12
    Super Member CleanIT's Avatar
    Aug 2019
    1,827
    1. Rinse car
    2. APC pre-soak
    3. Rinse
    4. Two bucket
    5. Rinse/dry
  4. Likes WhiteShadow89 liked this post
  5. #13
    Super Member John U's Avatar
    Mar 2006
    Eagan MN & Scottsdale AZ
    665
    How does “foam” work in dry conditions? Out here in AZ I find on a 65 degree day in the shade, Doing a rinseless wash one panel at a time, evaporation is fast!
  6. #14
    Super Member Optimus Grime's Avatar
    Feb 2023
    Concord, NC
    317
    Quote Originally Posted by briarpatch View Post
    Regardless of your method, there is always the potential to induce some type of marring during the wash phase. As Bill D indicated, his method is one of many that will reduce the chances of that occurring. I prefer to use a pre-wash foam (Bilt Hamber Touchless for me) first, to do the heavy lifting and carry the bulk of the dirt away. After rinsing that off, I will then wash with multiple mitts....but that's just me.
    That’s my new method and I find it works much better than just rinsing first. I find that using Auto Foam (switching to Touchless when it runs out) pretty much gets my car clean and the contact wash is just to remove that last little bit of leftover dirt. I use a few Autofiber Double Flip cloths to make sure any removed dirt never enters my wash bucket.
  7. #15
    Super Member Eric7810's Avatar
    Mar 2019
    330
    Quote Originally Posted by Big Dave View Post
    Does anyone else get "dirty" looks from neighbours when the foam runs down the driveway onto the footpath, I think they don't like walking through, or having to step over the rinsed off foam.
    It’s probably just in your head..
    But even if they are ‘upset’, they’re probably the same type of folks who grumble about how people today are lazy and nobody plays outside anymore like they used to.
    But once someone actually does either of those things they find another reason to be upset over what that person is now doing.
  8. Thanks Prange thanked for this post
    Likes DFB, Prange liked this post
  9. #16
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by BadgerRivFan View Post
    I’ll play devils advocate here and suggest that you should FOAM first, and then RINSE.
    Why?
    Because water is not a lubricant. If you power wash all the dirt and grit first you run a greater risk of marring the paint by blasting it with your pressure washer.
    Better to foam first, allowing the foam to dwell and begin to break down the contaminants while providing lubrication to then power rinse as much away as possible before beginning to do a contact wash.
    If you don’t want to foam first you could alternatively use a rinseless wash to pretreat all the panels before pressure rinsing, again with the idea of encapsulating the surface dirt and providing lubrication.
    Not convinced? I’m just repeating what I’ve heard from Yvan Lacroix in the past.
    You do you however Using snow foam to wash car.
    I will play devils advocate as well. This all sounds good and the theory sounds good. But there is no proof of this other than Yvan stating it. Not saying he is wrong but there is no proof and nobody has tried to capture this to show proof.
  10. #17
    Feb 2019
    66
    Quote Originally Posted by CleanIT View Post
    1. Rinse car
    2. APC pre-soak
    3. Rinse
    4. Two bucket
    5. Rinse/dry
    Op- Going to second the above CleanIT. That rinse in-between the foam and shampoo helps avoid the risk of product drying on a hot summer day, or even just a day with intense sunlight.
  11. #18
    Super Member Lance Mark's Avatar
    Mar 2021
    357
    where are those myth busters when you need 'em?...bet they could come up with some way of testing it
  12. Likes The Guz liked this post
  13. #19
    Nov 2015
    Los Angeles, California
    13,789
    Why?
    Marring the paint by using high pressure rinse? I honestly don’t believe that’s a realistic possibility. To take it even further, that would make it somehow possible to get swirls from driving a really dirty car in heavy rain.
    Water isn’t a lubricant?
    Car wash soap isn’t a detergent.
    -Car wash shampoo drying on a vehicle is less of a concern than plain water from the hose drying on a vehicle because car wash shampoo doesn’t cause water spots, water causes water spots.
  14. #20
    Mar 2019
    330
    Mar the paint by power washing it? Bruh.
  15. Likes Eldorado2k, The Guz liked this post
  1. Snow foam to wash car
    By cheekyage in forum Auto Detailing 101
    Last Post: 01-06-2022, 08:27 AM
  2. Snow Foam Test : Turtle Wax ICE Snow Foam Wash
    By alfierenadhie in forum Product Reviews
    Last Post: 06-09-2019, 09:41 PM
  3. snow foam test : poorboys super slick snow foam
    Last Post: 08-19-2018, 01:13 AM
  4. Replies: 3
    Last Post: 08-11-2016, 04:44 PM
  5. Wash during snow foam
    Last Post: 03-25-2016, 11:24 AM
