Results 1 to 6 of 6
    Regular Member szjalo's Avatar
    Sep 2011
    138
    Need recommend: microfiber cutting pads for DA
    I've been using Meg's microfiber cutting pads for the past few years. Meg's system has been working mostly fine to me (cuts well), but because they almost have no foam backing, I do find they are quite difficult for panels with any curves or contours.
    I am not quite up to date, but wonder if anyone can recommend me any microfiber cutting pads that cuts as great (or better) as Meg's but also deal with contoured body panels relatively well (i.e have foam backing?). Ideally for 5 inch DA backing plates
    Thanks a bunch!
    Regular Member Epilogts's Avatar
    Jan 2020
    Boulder, CO
    168
    Re: Need recommend: microfiber cutting pads for DA
    Quote Originally Posted by szjalo View Post
    Thanks a bunch!
    Rupes 150mm Microfiber would be a good alternative to the Meg’s pads. The 150mm work well with a 5” backing plate and work well with a DA.
    Sep 2011
    138
    Quote Originally Posted by Epilogts View Post
    is the 150mm (5.9in) measured as the size facing the backing plate or facing the car? if it's the size of backing plate, it probably is too large for a 5inch DA?
    Jan 2020
    Boulder, CO
    168
    I have many 150mm wool and foam pads that I use with my 5” backing plate. The Velcro loop on the backing of the 150mm pad is 5” in diameter and the pad face is 150mm.
    Actually sorry I forgot in microfiber only come in 130mm and 160mm and for microfiber so go with the 130mm microfiber for a 5” backing plate.
    Jan 2015
    Simi Valley, CA
    1,783
    Try a foam interface pad between the backing plate and the microfiber pad.
    Aug 2020
    929
    Griots Fast Finishing MF pad is good for light cutting. Slightly more cut than a LC orange pad.
  1. Microfiber cutting pads
    By cgdalton in forum Auto Detailing 101
    Last Post: 07-17-2020, 10:25 AM
  2. Microfiber cutting pads
    By precisionmobile85 in forum Wool & Foam Buffing Pads
    Last Post: 06-23-2018, 11:03 PM
  3. M85 with Microfiber Cutting Pads
    By Roman92 in forum Auto Detailing 101
    Last Post: 10-08-2015, 11:04 PM
  4. Microfiber Cutting pads VS polishing/finishing pads, any difference?
    By coupe07 in forum Wool & Foam Buffing Pads
    Last Post: 05-15-2015, 08:21 PM
  5. Microfiber Cutting Pads
    By Grifffx4 in forum Ask your detailing questions!
    Last Post: 07-17-2014, 06:59 AM
