Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Sep 2016
    164
    Dont make my mistake
    Hi all, this is embarrassing, but wanted to share it to possibly save someone else from my mistake. I few of the detailing YouTube channels i follow recommend using a scrub pad on glass with stubborn grime. Having seen folks on here recommend 00 steel wool for glass, i figured it would be fine. Yesterday i finally tried it, using a Green Scotchbrite pad. Clearly, i chose the wrong pad. I sprayed the windows with glass cleaner, lightly rubbed them, and used a two towel method to finish. Well, after i had done all 4 door windows, I noticed some scratches, I looked closer, and it looks like someone ran sandpaper over my windows. Ive already tried my glass polish on a heavy cut pad. (knew it wouldnt work but had to try)
    So learn from my mistake, DO NOT use a green scotchbrite pad.
  2. Likes chilly, Coatingsarecrack liked this post
  3. #2
    Super Member Bosko's Avatar
    Oct 2021
    Michigan
    1,584
    Re: Dont make my mistake
    sorry man
  4. Likes opie, PaulMys liked this post
  5. #3
    Mar 2011
    PA
    5,793
    It happens. We have all been there including me. For glass stripping I have found STONER GLASS STRIPPER completely safe and effective. You can get it locally. For some reason I see AG no longer, has it?
    2018 Colorado ZR2
  6. #4
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,774
    I have found that even the finest grade of steel wool will scratch auto glass, luckily I did a test spot so my damage was limited to a small area, maybe 5"x5"
    Chalk up one for the YouTube "experts"
  7. Likes oneheadlite, Coatingsarecrack liked this post
  8. #5
    Super Member Lance Mark's Avatar
    Mar 2021
    357
    thank you for the heads up
    i recently used a green scrubby on polished aluminum, but I did it on purpose knowing it would dig in....the surface was etched with deep water spots and I knew that green scrubby would be a good start for getting at those etched spots
    I would have thought glass would be too stout to be damaged by a scrubby....again, thank you for posting
    sometimes we do stupid thing...it's why we need each other
    we should start a "really stupid stuff I've done" thread....I could start by telling you about the time I drove a bolt through the front fairing of my beloved harley davidson....i literally started sweating when I realized what I'd done
  9. #6
    Sep 2016
    164
    Quote Originally Posted by Lance Mark View Post
    At least it was my car and not one of my friends. The worst part is that its on my 2021 and not my 20 year old truck -_- It looks like windshield roadrash, I HATE It.Ah well. At least I didnt hit the windshield.
  10. #7
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by 04lss View Post
    Ouch.
    The white pads are the most aggressive yet still safe from scratching glass. They will remove waterspots safely and last longer than 0000 steel wool as they are also prone to rusting and flaking off dangerous bits that can then get caught in a drying cloth or polishing pad (wouldn't be good)
    XERO White Scrub Pads | Abrasives | WCR
    If you're looking for something even safer, there's walnut pads.
    XERO Walnut Scrub Pad | Abrasives | WCR
    2023
  11. #8
    Super Member Big Dave's Avatar
    Jan 2018
    Slightly north of Sydney, Australia.
    2,294
    Maybe it scratched because it was the 2021, maybe the glass is softer in newer cars. Not that I'm proposing you do a test on your old truck to find out. I bought some Ceriglass to remove a whole bunch of fine scratches from my windscreen. I don't think the previous owner ever cleaned it, other than squirters and wipers, all the fine scratches matched the arc of the wiper blades. Ceriglass removed 90% of them.
  12. #9
    Sep 2016
    164
    Quote Originally Posted by Big Dave View Post
    I have Griots fine glass polish, and hit it with that, and it didnt even notice.Not sure if ceriglass is stronger or not. I got qouted 500 bucks to replace the front windows... might take them up on that.
  13. #10
    Jan 2018
    2,294
    I have other glass polishes as well, but Ceriglass is definitely stronger, I've only used it once, no other glass was that bad. And it's relatively inexpensive.
    CARPRO CeriGlass Polish Kit (150ml) - Skys The Limit Car Care
  1. Did I really just make this ROOKIE mistake!!!!
    By Chase361 in forum Auto Detailing 101
    Last Post: 07-09-2015, 12:00 AM
  2. Did I make a mistake buying the PC 7424XP?
    By movingforward in forum Auto Detailing 101
    Last Post: 01-08-2014, 12:19 PM
  3. Detailing as a business? Don't make this mistake!
    By Bates Detailing in forum Off-Topic
    Last Post: 06-27-2012, 09:55 AM
  4. Detailing as a business? Don't make this mistake!
    Last Post: 06-26-2012, 09:39 PM
  5. Did meguiar's make a mistake??
    By rustytruck in forum Auto Detailing 101
    Last Post: 04-03-2012, 09:54 AM
