Super Moderator
Re: YOUR MOST TRUSTY BRUSHES?
Brushes are a last resort for me... The only exception might be tires.
Every brush I have ever tried will scratch or mar delicate surfaces regardless of their claims otherwise.
I only have a few brushes. Two for the wheels, a soft one for faces and a long Speedmaster one for the barrels. The others are some small, soft ones. The softest is used to clean around badges and logos on the outside. The other gets used for brushing out bits of crud from around buttons or other seams on the interior.
on a bike, there's not much to do with a brush other than a tooth brush....i use it to clean the calipers when the pads are removed....i use it to get into some nooks and crannies underneath and in the front near the oil filter location on a vtwin engine....sometimes if washes aren't cutting the grime that builds up on the underneath of fenders, i hit those with a brush
I have a bunch, but actually use very few, all depending upon the task(s) at hand. But… if a green CG Wheelie is scratching a rim face, there’s something wrong with the rim, not the brush.
Originally Posted by
2black1s
most all brushes will scratch it's just the severity on how bad & quickly it does it...
Bobby B.
Desertnate
SameGuy
VISITOR
WRONG SECTION
VISITOR
So dramatic! I'm going to officially dime this "DETAIL QUEENS"
