What’s your TOP GUN on heavily scratched paint?
I’ve jumped in head first after 15 years off detailing. Needless to say detailing has evolved light years since!
I’ve been Having phenomenal results thanks to all of you guys!
I’m curious what would be your 1st gun on someone else’s rotatory mess?
I know to take the least aggressive route first!
I’ve been kicking around whether to even pull out the rotary. I've been using the BEAST almost exclusively with great results! I'll defiantly go with forced and a blue LK HDO CCS and Cutmax then Menzerna Heavy Cut 400
Assuming the results fall short, what would be your TOP GUN?
Thanks in advance! And I will post pics and what did the trick.
Re: What’s your preferred 1st weapon of choice?
It's really job dependent.
But an orbital with a foam polishing pad, and your polish of choice (or an AIO), probably covers 95% of the work out there.
I would try the beast first.
Originally Posted by
2black1s
noorth
Hey Buddy Noorth!
I've been using it dam near exclusively. It's been a game changer! I agree with you on trying it first. But if that doesn't cut deep enough, I was hoping to hear other options?
Re: What’s your TOP GUN on heavily scratched paint?
Microfiber i suppose....or wool and rotary.
A lot of detailers i've read about do the majority of heavy cutting with microfiber on a DA. Meg's cutting discs, uro-fiber, blue LC and blue rupes etc
noorth
Microfiber is a no no for forced rotation
DanaDetailingPros
I’m curious what would be your 1st gun on someone else’s rotor mess?
I know to try the least aggressive route first!
Supa beast and orange lc force pad 3d aca510, if that fails then id grab my flex rotary and lc purple foamed wool pad 3d aca510, if that is not enough then swap the purple foamed wool for rupes coarse blue twisted wool pad 3d aca510.
Thats just my general thought but as 2black1s said each situation is different.
Side not if you like menz 400...may i suggest 3d 510. Im my view its all around better product. Easier wipe off cuts fastand finishes down very nicely
My most used heavy cutter is 3D ACA500 on Buff and Shine Uro-Fiber pads. That's if the green foam isn't going fast enough.
I still enjoy using those old school green foam Buff and Shine or Hex Logic pads if I want to cut to any degree with foam. They're designated as a polishing pad, but they always cut better for me than the hard, dense orange or yellow. I used to use them with Meguiar's Ultimate Compound a lot back when I started.
The problem I'm having now with those foams is that they're not being made for long throw polishers (aside from the CG Quantam Hex Logic) in a contemporary range of sizes. The smallest is a 4"! I use 1" and 3" pads sometimes.
Outside of that, I REALLY like the LC HDO CCS for foam defect removal.
I'll start with 3D ONE on any detail, but if needed I'll go to the ACA500 compound.
Other compounds I really like:
Meguiar's M110
Carpro Ultracut
Jescar Correcting Compound
Sonax Ultimate Cut
I also used to use the Rupes Zephir when I was using the old Rupes system. I'm not in love with their new system (but I do like their wool pads, and plan on picking more of then up), but I still have the old liquids and a ton of the original microfiber in my personal stock. I'll use those from time to time as well. The new DA Coarse I found really dusty, more so than Meguiar's M105. I'm thinking the culprit is their priming recommendations. Way too much material on the pad for me. If I ever try it again, I'll use the procedure that works for me, which starting with a few drops, and letting the pad self prime.
Sometime I wonder if some of these companies don't start with promoting their procedure before the results and user experience.
opie liked this post
dlc95
Have you tried aca 510 yet? I had aca500 and loved it, but when i ran low i got 510 instead. The only difference i had found was that it cut faster. Mike p also said that the main difference was more powder in 510 compared to 500..hense faster cut
so your saying Beast w/3D500 and uro-fiber correct? I do have the Uro pads and 3D One is what I'll try 1st. Or should I start with a Blue LC HDO CCS? I just ordered the ACA500 since it's been on my list for quite awhile. I only Sonax I have is Cutmax and Perfect finish. I also have 3M #2 and MG 205
