Page 6 of 26 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 255
  1. #51
    Super Member CleanIT's Avatar
    Aug 2019
    1,826
    Re: First day using Bilt Hamber touchless.
    You can also use BH AF in a sprayer. Works as well or better than foamer.
  2. Thanks chilly thanked for this post
    Likes chilly liked this post
  3. #52
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,775
    Quote Originally Posted by CleanIT View Post
    Are you using the same dilution ratios with a sprayer?
  4. #53
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,226
    Quote Originally Posted by chilly View Post
    I use i think its 9 or so oz of touchless in 2 gallon garden sprayer
  5. Thanks chilly thanked for this post
    Likes chilly, CleanIT liked this post
  6. #54
    Sep 2020
    Eastern PA
    1,792
    Quote Originally Posted by chefwong View Post
    How are you guys liking your touchless with BH. I used to import $$$ jugs from overseas with the many many threads over at DW.uk
    Had subpar results.
    I swore off importing said goods and while I have looked at the BH touchless many a times recently, I don't plan to spend many of pre-wash products anymore...
    I swore off pre-washes or at least importing the good stuff
    I'm just thinking the chemical-ology is just made for the water they have over there and not the water we got here ;-)
    There's a domestic importer of BH. I was chatting with them about it when I was in their store. Doesn't seem like they have any exclusivity to import it. Sounds like it takes them 6-8 months to get things shipped and thru customs, etc. Could be a challenge for anyone deciding to do that without initial supply disruptions.
  7. #55
    Aug 2022
    Dana Point CA
    1,322
    Amount of water X 0.04
    I use 2 OZ. with my foamer 48oz X 0.04+1.92
  8. Thanks CleanIT, opie thanked for this post
  9. #56
    Dec 2018
    7,177
    Had subpar results.
    Did you get the dilution right? BHAF has been the only Pre wash I’ve used that makes a significant difference
    My results are here and you can see a major difference.
    What are your opinions regarding Bilt Hamber Auto-Foam?
  10. #57
    Mar 2017
    Southeastern PA
    2,480
    I used Touch-Less today for the first time. Car wasn’t too dirty so I did a 2% PIR using a PF22 foam cannon. After calculating the flow from my power washer, 2% PIR called for 7oz of soap in the cannon. 4% PIR would be 14oz. Looks like I’ll be using the 5L pretty quick.
    I was impressed by the results. The foam running down made me see how the car wasn’t all that clean. And my driveway was dirty because the foam was brown as it ran down the asphalt.
    After foaming I rinsed with deionized water and dried with my ego 765. Truly touchless
    Only touching I did was to apply some tire dressing. Came out pretty good.
    Bruno Soares
  11. Thanks CleanIT thanked for this post
    Likes MisterSnoop, PaulMys, opie, chilly, CleanIT and 1 others liked this post
  12. #58
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Quote Originally Posted by Bruno Soares View Post
    Damn, that came out pretty sweet Bruno!!
  13. Thanks Bruno Soares thanked for this post
    Likes Bruno Soares liked this post
  14. #59
    Aug 2022
    Dana Point CA
    1,322
    I had a roof only correction last week and I didn't want to conventionally use a foam cannon nor a soapy bucket and hand. But I also didn't feel like diluting at 4% So I did 2% and it did the trick just fine. Only thing I noticed was the foam wasn't as thick but it loosed everything just fine to pressure off!
  15. Likes Bruno Soares liked this post
  16. #60
    Dec 2018
    7,177
    So when using in a foam cannon BH says to use sparingly. You don’t need to drench the car. Literally if it’s got a coat on it your good. One PF22 filled should do 2-3 times.
    To be more economical get an IK foam pro 2. 4oz to 100oz of water will clean your suv 1.5-2 times…
  17. Thanks CleanIT, Bruno Soares thanked for this post
    Likes Bruno Soares, opie, chilly liked this post
  1. Bilt Hamber Snow Foam
    By swanicyouth in forum Auto Detailing 101
    Last Post: 07-05-2019, 06:47 AM
  2. Bilt Hamber double speed wax ?
    By HU11LK in forum Auto Detailing 101
    Last Post: 09-20-2017, 09:33 AM
  3. Bilt Hamber DSW hazing issue.. please help
    By boogyman in forum Auto Detailing 101
    Last Post: 09-04-2017, 03:58 PM
  4. Anyone used Bilt Hamber double speed wax?
    Last Post: 08-15-2017, 04:49 PM
Members who have read this thread: 78
