Can confirm Bilt Hamber Anti-Corrosion Properties.
So, not sure if I mentioned it anywhere on here but I have two Griot's Garage Brillant Shine Foam Cannons. One for pre-wash, and one for standard shampoo. Well after a few washes I noticed that if you didn't let the foam cannon dry out the metal ball on the end of the pick-up tube rusts. Huh!? Why in the world would Griot's cheap out on a $60 Foam Cannon and not use stainless steel for the pickup tube weight? So dumb, and quite frankly unacceptable. First time I've been able to bash Griot's hardware.
Anyways, the first pre-wash to be used in the cannon was Carpro Lift, this is when the rust started. After my quick no contact wash I pulled off last week(only dusty) I noticed that all the rust on the ball thingy was gone, in fact, it was shinier than new! The Bilt Hamber Touchless, after a few uses, removed and has since kept rust from forming on the pick-up ball thingy. Needless to say I was VERY pleased to see confirmation on a products performance, even if it wasn't on the car itself. This makes me wonder.... does regular Bilt Hamber Touchless use negate the need for periodical use of fallout removers? Maybe...only time will tell how clean the paints stays. But I figured I would share this here. Bilt Hamber is continuing to look more and more appealing to me.
2019 GLI 35th Edition DSG in Pure Grey w/ OEM+ IS38 turbocharger and various bolt-ons.
Re: Can confirm Bilt Hamber Anti-Corrosion Properties.
Originally Posted by
PouncingPanzer
I believe the pickup tube ball rusting is a known issue that they've acknowledged and have since resolved. If you reach out to customer service, they'll probably send you a replacement.
MisterSnoop
Having a guy at work make me some out of 316 stainless, but glad they're correcting their error is material choice. It doesn't take a genius to know that it should be legit stainless given the application and operating environment.
PouncingPanzer
Just picked up some Bilt Hamber Surfex HD APC......been very satisfied with it so far. I was an Optimum Power Clean person for quite a while, but this has replaced it.
