Re: Griots Complete Compound vs. Megs Ultimate Compound
Another thing is to use a water spot remover to break down the water spots. Then come back with a compound or polish.
Originally Posted by
PaulMys
Is UP still harder than Chinese algebra to remove?
That was my only beef with it, and the only reason I stopped using it years ago.
Only when I start with the three drops - sometimes.
This bottle is worse with it than the ones I've had in the past.
I just had a similar issue OP. Same as you- i used ultimate polish and several spots remained after about 4-5 passes. I ended up going in by finger tip with UP on a microfiber towel on the trouble spots. I used it very sparingly/dry. It worked. It cleaned up the spots easily. Then I did a couple more passes on the whole thing with the DA to finish. Worked like a charm.
I have them both and for what I was using them for they both fell short I switched to megs 105 (100) can't remember the number
