Maguire's Hyper Dressing turning tires brown
Using Meguiars hyper dressing for shine on my tires. It is turning my wheels a brownish color. Which doesn't come off with light brushing and simple green.
Anyone experience this.
Re: Maguire's Hyper Dressing turning tires brown
Stop using Simple Green to clean tires. The caustic nature or chemical make up of that cleaner may be doing something funky to the rubber. It may be leaving a residue behind or you may not be fully cleaning the tires correctly.
Pick up a GOOD dedicated tire cleaner locally which would be Turtle Wax Hyper Foam Wheel Cleaner and Tire Prep. You can find at Walmart, Advanced Auto, etc.
Clean tires until foam is white. Dry tires completely. Then apply Hyper Dressing and see what your results are.
Super Moderator
Yes stop with simple green. Megs d143 or snag a gallon of 3D yellow or orange degreaser and cut it with water to whatever strength you need. It is a very good product and great price.
Also use a stiff wrestle brush and scrub tires not a soft one
Originally Posted by
Luket
The brown is called Blooming and isn't from Hyperdressing. I've been using it for years with no issues.
Black Magic Bleche-Wite Tire Cleaner is cheap and effective at removing the brown blooming that you're seeing. If bad, it may take 1-2 scrubbing sessions.
As others noted, stop using Simple Green. The blooming is from the tires releasing antiozonant which is part of the manufacturing process. It actually prevents dry-rot and tire-cracking caused by ozone, sunlight, etc. that tires are exposed to. Simple Green likely causing it to be pulled out in droves.
I ordered some Carpro Multi X for tires. Reset wasn't removing enough of the brown.
NJNinja
Have you tried TW Hyper Foam Tire cleaner yet? You really need to. It's that good. I washed my sons Cruze yesterday. Its been 30 days since I washed it last. Parks outside 24-7 and he drives it daily. 2 applications of the cleaner and the tire is coating ready.
I've tried many tire cleaners. And I just don't see the need to pay MORE money for cleaners that do relatively the same thing that TW can do cheaper and faster.
evo77
I haven't but thanks for the suggestion I will try it.
NJNinja
I would recommend a dedicated tire cleaner such as Tuf Shine, 303 Tire and Rubber or the TW Hybrid Foam Tire. Leaner Don and Evo77 seem to like. Not sure Multi-X will do as well.
We primarily use Hyper Dressing at work and don't see it browning the tires.
We clean them with Optimum Power Clean 3:1, or straight depending on how bad they are.
DFB liked this post
