Results 1 to 10 of 10
    Apr 2020
    Shop vac too powerful- fix or new vac?
    I have a 5HP Dewalt shop vac but I find it’s too powerful, as soon as I touch the carpet it just wants to pull the carpet off…
    is there a way to work around the suction power, or should I purchase a smaller vacuum system for vacuuming up every day dirt from the carpets? If so, and money was no object what would be the best choices?
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Shop vac too powerful- fix or new vac?
    I've never heard of "too much". And I've certainly never experience "too much".
  3. Thanks RamAirV1 thanked for this post
  4. #3
    Nov 2015
    Los Angeles, California
    13,765
    Drill holes in your attachments. The air needs to vent.
  5. Thanks oneheadlite thanked for this post
    Likes PaulMys, mattmann liked this post
  6. #4
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Use a brush attachment, or notch the ends of your existing attachments to allow more air in as Ric mentioned above.
  7. Likes mattmann liked this post
  8. #5
    Apr 2020
    Perfect that’s the “fix” I was looking for! That’s the issue now I think about it- it basically suctions on and won’t let go which makes it hard to move.
    So just make a couple small drill holes and add more as necessary?
  9. Thanks Eldorado2k thanked for this post
  10. #6
    Nov 2016
    Drill holes yes that the easy way
  11. #7
    Nov 2015
    13,765
    Quote Originally Posted by ps2cho View Post
    Correct.
  12. #8
    Super Member MikeyC's Avatar
    Mar 2006
    Massachusetts
    885
    Even easier . . . when using the vacuum just hold the tool at a slight angle so that the end of the tool isn't 100% flush with the surface of the rug. If you don't allow a seal to be created at the end of the vacuum tool then you won't get that suction affect that's bothering you.
    You like Nattys, I like Souveran, and Justin is DP MaxWax. And you know what, its alright !!
    -Killrwheels
  13. #9
    May 2020
    394
    I like the idea of brush or notching the end.
    Just thinking out loud, if you drill some holes in the side of the attachment, air would more likely flow through those and not through the opening that is contacting the carpet.
    Notching the end allows the air to flow through right at the point of contact between the attachment and carpet, possibly increasing the cleaning 'power' of the vacuum because the air may blast through the carpet fibers, dislodging the debris.
    But then again, it might not really make any difference.
  14. #10
    Super Member Icarus's Avatar
    Oct 2019
    Ontario, Canada eh!
    269
    If you drill holes in it, put them close to where your hands go so you can cover them up for 'extra' power when needed...
    ·Ï¢årµ§·
  1. Porter Cable's ARE powerful.
    By heckhole in forum Auto Detailing 101
    Last Post: 10-27-2015, 01:35 AM
  2. is this the most powerful PC style DA yet?
    By VISITOR in forum Auto Detailing Tools and Accessories
    Last Post: 08-04-2015, 03:13 PM
  3. Will this be powerful enough?
    By detailedsd in forum Ask your detailing questions!
    Last Post: 02-23-2015, 08:38 AM
  4. Big Black and POWERFUL!
    By CrownKote in forum Show N' Shine
    Last Post: 06-07-2011, 07:01 AM
  5. May want to step up to a more powerful DA
    By mcpp66 in forum Ask your detailing questions!
    Last Post: 02-28-2010, 04:30 PM
