Super Moderator
Re: Can I remove these stains on a budget?
Do you own an Extractor and Steamer for detailing interiors? Those seats look pretty stained and would require some deep cleaning / extracting. The dashboard doesn't look too bad and should cleanup with the D101 diluted.
Originally Posted by
Bobby B.
Hi Bobby, I do not own those unfortunately. I know I won't be able to get stains fully out, but i'm hoping I can at least fade them down until they aren't as noticeable as they currently are. Do you think there's a budget friendly product I can use on the seats/carpet?
Super Moderator
Meguiars D101 at 1:10 or 1:15 would be a good starting point. Focus on your technique with a few microfiber towels. Work on blotting with a barely damp D101 towel followed by a microfiber towel barely damp with water and finally blot with a dry towel. You’re trying to remove the stain and if you get the area wet, you’ll push the stain down into the foam and it will return. So just blot with a little scrubbing action but no saturating. Good luck.
Depending on what made the stain, you may need to look at getting an enzyme cleaner, which Autogeek has. And if you place an order, you might want to get Chemical Guys Lightning Fast Carpet and Stain cleaner, which is a surprisingly good product for stains.
I had a similar situation when I was on the road. I had Megs D101 in my detailing bag and it just didn't cut it. When I got home I used Wolfgang Carpet and Upholstery Cleaner and it removed the stains. It is really best to use a cleaner that is specifically formulated for fabrics.
I believe in treating everybody with respect, and clean cars. That’s what I believe in.
Try Folex, it worked for me.
