As some of you may alredy know. Last week i applied evo pure coating on my black audi. After 10 days of curing i decided to washed the car and applied cancoat evo on top. It rained quite a bit last week so removing the water spots was a bit of a pain. I had to use ipa on some spot on the hood but the car was ready for cancoat
I ve decided to use esoteric method of applying cancoat spray on the microfiber and doing small sections. I started on the hood and pretty much gave up. Let me start by saying the spray method is a pain , real pain because it goes everwhere so i had to make sure it only went onto the microfiber. The coating itself is sticky and not slick, it does not come off easy , its even worst than a ceramic coating because u are not applying it with a suede block or microfiber applicator. The car is black so it makes it worst because i had to go over 5 or 6 times just to make sure they were not darker spots. Working on small sections also make it harder as u end up going back to the sections u already did, which against causes darker spots there. Furthermore the fast curing time makes it harder to go back and fix the spot u missed.
I ll be honest , the car being black doesnt help, the lighting in my garage is not the best so it doesnt help neither. Not going to lie , i would rather just do a second coat of ceramic coating instead of cancoat or i would apply cancoat with a suede applicator or microfiber applicator, treat it like a true ceramic coating next time
Overall thoughts are i would rather use carpro gliss as a topper rather than cancoat
I would even argue that carpro lite was easier to apply than cancoat evo.
Even pure was easier to come off and it is as slick as cancoat
just wash them and they will be fine.
