Results 1 to 9 of 9
Thread: Spider Pads
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    Spider Pads
    So from the folks who have actually tried or use them-- What do you think of them?
    Disregarding the cost factor-- what are your pro's & cons of them ( likes & dis likes )
  2. Likes chilly liked this post
  3. #2
    Regular Member Epilogts's Avatar
    Jan 2020
    Boulder, CO
    168
    Re: Spider Pads
    I’ve got a stash of “Honey” spider pads to use for finishing.
    I believe most are a 'reticulated hybrid' foam which is a semi open cell foam (aside from the orange which is closed cell foam) that makes them somewhat stiffer by comparison. This makes them much more suitable for DA usage, as the foam will not distort or bunch on these machines as soft pads can. However, they are compressible and flexible enough to contour as much or slightly more than a Buff & Shine/Chemical Guy’s Hex-Logic White pad that many will be familiar with, which - combined with their height - makes them utterly sufficient to adapt to concave curves.
    The Spider cut foam creates a space for the swarf to go, theoretically allowing for more polish contact with the paint and a quicker/cleaner finishing time.
    The cut level of the Honey pads falls between a Lake Country Hydro-Tech Crimson, and a Scholl Concepts Orange pad and LC HT Tangerine pad. They provide a decent amount of cut to help remove marring from more aggressive compounding steps, unlike the soft open cell foams many associate with ‘finishing pads’. Due to their design, however, they are capable of maxing-out the finishing potential of polishes to a much greater extent.
    Due to their design I believe they are very suitable for DA usage, as the foam will not distort or bunch on these machines as other soft pads can. However, they are compressible and flexible enough to contour as much or slightly more than a Buff & Shine/Chemical Guy’s Hex-Logic White pad, which - combined with their height - makes them useful on concave curves.
    For the rock hard paint I normally deal with they work good for jeweling but I think someone with soft paint (or for piano black) would really enjoy how these pads work and don’t leave much haze.
  4. Thanks luckydawg thanked for this post
  5. #3
    Jan 2016
    1,117
    Re: Spider Pads
    only 211 views and one reply--that alone answers my question
    Not gonna waste my money & time on a gimmyk
  6. Likes chilly liked this post
  7. #4
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,868
    Re: Spider Pads
    I was hoping for input as well
    I am curious because 3D has Spider pads and CarPro USA has Spider pads
    The colors are different but I gotta think they are likely the same product
    I have never been one for waffle or scalloped or spider cuts etc
    But I can certainly be schooled if I am missing out on something revolutionary
  8. #5
    SELF BANNED
    Jun 2019
    1,076
    Re: Spider Pads
    Scholls and 3D sell spider pads. I was always curious about them but they don't seem very popular on this forum. They have been around long enough now to get a good following you would think....if they are really good or different - in a good way - than lake country for instance.
  9. Likes chilly liked this post
  10. #6
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    Re: Spider Pads
    I never liked any of the gimmicky pads like these. Stick with a regular pad that is just flat on the bottom.
    All these dimples, pimples, cross groves, spiders, miters, honey combs, Frosted Flakes and whatever else add nothing to the buffing cycle and make the pads harder to clean.
    Jim
  11. Likes chilly, luckydawg liked this post
  12. #7
    Sep 2017
    Sweden
    3,022
    Re: Spider Pads
    I have used Scholl White Spiderpad and it's very scary to use the first time. It's rock hard and some mix of foam and wool I believe it is. But for haveing that much cut it still don't haze the paint so much with Scholl S3 XXL. It's the most cutting foam pad I have used and about the same cut as Meguiars Microfiber Cutting pad if not just a touch more.
    The second I have used is Scholl Spiderpad Honey the orange. I would compare to Rupes yellow foam pad the older version. They both hold up and is a great quality. I don't have access to B&S and LC when I bought a lot of pads. Now I can get LC pads here in Sweden easly. So just wait a little while until I need some new pads. Have 5-7 cars this spring to be polishing. So after that I probebly need to get some new pads again and will try out some LC HDO and microfiber pads.
    Starting to get access of little more knowned US brands that's talked about here. So will as the times goes test out some more products that I know from you guys here. Don't know how 3D Spiderpad is against Scholl. We just got a distributer here in Sweden for 3D. So I will try out 3D One soon I think. And Scholl both the maroon and blue Spiderpad. Is popular here in Sweden as one step pads. On medium hard paints with the maroon and blue on hard paints. They combo this with Scholl S20 or S2 or Angelwax Enigma AIO. Enigma AIO gets a lot of love here for it's cutting ability on hard paints. And still finishing really well on aggressive foam pads. Think german and Volvo cars.
    Skickat från min SM-T736B via Tapatalk
  13. Likes chilly, noorth liked this post
  14. #8
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    Re: Spider Pads
    I have used the scholl spider pads for many years. Yes they are a little more expensive than some others but not far off of Rupes pricing. They are VERY durable and like mentioned earlier, even the harder cutting pads leave minimal haze if any. I’d say if you’re polishing cars here and there then you don’t need these. If you’re polishing on a regular
    basis, these pads will show up time after time.
  15. Likes chilly liked this post
  16. #9
    Super Member psnt1ol's Avatar
    Aug 2012
    San Francisco
    892
    Re: Spider Pads
    I use the 3D light purple spider pad for One step (with 3D Speed or Blackfire one step) when i need to get around the vehicle fast. I feel that they are meant for a production style of work. Does well all around but nothing spectacular in any specific category. Your mileage may vary but i find the pad stalled a bit less with them on a long throw machine.
  17. Thanks luckydawg thanked for this post
  1. Purple spider pads with a AIO.
    By Indiglofish61 in forum Auto Detailing 101
    Last Post: 04-10-2019, 02:32 AM
  2. Thoughts on 3D's Foam pads / spider pads
    By TTQ B4U in forum Auto Detailing 101
    Last Post: 09-20-2018, 11:31 AM
  3. Spider web
    By kevincwelch in forum Off-Topic
    Last Post: 06-13-2017, 07:51 PM
  4. What to do for spider web
    By akj in forum Auto Detailing 101
    Last Post: 04-01-2013, 11:06 PM
  5. Need help getting rid of spider web marks.
    By hitman34608 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 12-20-2008, 11:33 PM
