one thing for sure....even if it comes off, you are still going to see where it was.
I think that has damaged the clear coat having been of the paint for a loooooong time...
Looks like not only adhesive but part of the actual LT label itself. Look how thick it is on passenger side. I dont see how that is all adhesive. Especailly since you can still see remneants of the LT letters
Looking at the residue you’ve got on that cab I think it would take quite a while with chemicals and elbow grease. The 3m eraser wheel would get it off but you’ll need to polish afterwards and be careful not to induce too much heat…
I’d go for a microfiber or wool pad on a DA and a fine polish (mostly to cool the pad a little). It will remove the adhesive and should leave you with a good finish without any risk of damaging the paint below.
This is correct, I took a better look at it. I do have a 3m eraser wheel that I can give a try. The paint is not in great condition on the truck so not that concerned about it. Just want to clean it up some.
