Scangrip Minimatch, Sunmatch or Matchpen R
I am a home detailing hobbyist, only maintaining my wife's and my own cars. I am looking for a light for routine maintenance.. finding / correcting swirls, waterspots smudges etc.
From a practical standpoint which among the Minimatch, Sunmatch 3 and Matchpen R would best suit my needs?
Re: Scangrip Minimatch, Sunmatch or Matchpen R
My MatchPen R has been great, I use it often for the majority of polishing due to the size utility of it. My rear button did go out after a few years and ScanGrip warrantied it without issues and sent me a new unit. I recently picked up the Meguiar's MT103 Sunlight 3+ which is made by ScanGrip and is the direct alternative to the SunMatch 3, I've also been enjoying it. You can now find the Meguiar's MT103 for around $99, which makes it by far the best value ScanGrip at that pricepoint. Separate buttons for brightness and color temps, and the memory function means you can turn on/off/on with one button and it will save all your previous settings when you next turn it on. No more hunting through light modes/brightness every time you want to turn it on/off like some other lights.
The MatchPen R you can adjust color temp and how wide/narrow the band of light is, but no brightness adjustment. Out of the box I think the brightness level is pretty spot on. The MT103 has full adjustability with a range of color temps and brightness levels. I wanted the MT103 as soon as they released it until I saw the pricepoint was around $250 or so. When I saw them drop down to $99 recently I bought one instantly. Need some more time with it to see if I'll grab for it over the MatchPen R. I don't have any experience with the smaller MiniMatch.
Is the Multimatch R too expensive? That light is awesome.
Or better yet, the Gyeon branded one (PRISM Plus) because it comes with diffusers. It will be handy when you do a coating job.
As it turns out I found a used (returned?) MiniMatch in Amazon Warehouse for only $49, so I will be trying that out first.
I will never do coatings
thanks
So question on lights, can you not use any decent led flashlight, does it make a difference between the lights catagorized as swirl finder lights??
Depends on what you're looking for. A bright white (5000K+) light is better for finding swirl marks and scratches. A more diffuse, warm light (<4000K) is usually better for finding high spots when doing coatings. And indirect lighting is often better for finding high spots than shining a direct light.
Here is an excellent explanation of what works as far as lighting goes for paint correction
It gets technical but the takeaways on what color temperatures to use are worth the read
Auto Detailing Lighting Explained for Paint Polishing
I hope this doesn't violate any forum rules
If it does let me know and I will delete it
I think it's good information reading, it should almost be a sticky.
No issues with my Braun color match light.
I mount my Scangrip Multimatch R on a tripod for working in a garage.
I have a scangrip handheld knockoff from harbor frieght. Works for me.
I will say if i did this fulltime i would invest in one of tge big scangrip multimatch lights. I used my buddys in his shop b4 and it was awesome for lighting up a work area when ceiling lights arent cutting it.
Last Post: 08-20-2018, 06:17 AM
Last Post: 08-20-2018, 05:51 AM
Last Post: 08-20-2018, 05:46 AM
By Mike Phillips in forum Sales & Promotions - For forum members and non-forum members
Last Post: 05-18-2017, 08:27 AM
By k20trick in forum Product Reviews
Last Post: 05-16-2017, 03:54 PM
