Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Super Member vaca22's Avatar
    Feb 2020
    380
    Backing plates - what do I need?
    I'm looking to get a G9 but want to swap out the 6" backing plate for a 5" plate. I noticed the store has Lake Country plates as well as the Griot's plates, but the Griot's seems kind of expensive. I'm assuming the LC plates are okay to use??
    I also have a spare PC 7424 that I'm going to convert to 3" for smaller areas. I'm guessing the LC backing plates would be cool for this application, correct?
    Let me know if I'm missing any important details. I feel as if something about a counter weight was a big deal back when I first purchased the PC, which would have been in 2004 or 2005.
    Feb 2012
    Palatine Illinois, USA
    24,595
    Re: Backing plates - what do I need?
    I bought the conversion kit from Griot's garage to go from 6" to 5" and 3" to 2" and they work out very well!
    2022 Elantra N Cyber Gray
  3. Thanks vaca22 thanked for this post
  4. #3
    Super Member Goonie75's Avatar
    Feb 2017
    696
    Quote Originally Posted by vaca22 View Post
    I prefer the griots due to the cooling holes. Their 3" is the same. 2 inch too. 1 inch isn't. You can put a 3" on a porter but man do they vibrate. If you can splurge, get the G8. It changed my world. Lol
    Good luck
    Ryan
    Sent from my SM-G965U using Autogeekonline mobile app
  5. Thanks vaca22 thanked for this post
    Likes chilly liked this post
  6. #4
    Sep 2020
    Eastern PA
    1,798
    I would say to stick with the Griot's 5" vented backing plate as mentioned. If you get it during a 25% off sale, it's $15. You could go with another backing plate but might not have as much cooling.
  7. Thanks vaca22 thanked for this post
  8. #5
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,822
    After I got my Rupes 15 I demoted my PC down to permanent 3" duty
    Like yours, my PC came with the counterweight to allow 6" use but 5" was the most I ever felt it was comfortable with
    I can't say as I have ever seen or more importantly, FELT an issue with the 6" counterweight running a 3" system
  9. #6
    Feb 2020
    380
    Quote Originally Posted by MisterSnoop View Post
    I'm bummed I missed the last sale just now. Wonder when the next one will be?
  10. #7
    Sep 2020
    Eastern PA
    1,798
    It can't be that long. St Patrick's Day sale? First Day of Spring sale?
  11. Thanks vaca22 thanked for this post
  12. #8
    May 2006
    Alaska
    1,822
    I just went on a well known repair parts site and the PC 7424XP parts section only shows a 5" and 6" counterweight so I guess if you run into vibration issues after going to a 3" pad you might get a better result by buying the 5" counterweight
    It would be interesting to see what the weight difference is between the two because if the 5" weight is lighter I would think you could play around with your existing weight and possibly "tune it" for 3" pads by drilling it out a bit at a time
  13. Thanks vaca22 thanked for this post
  14. #9
    Aug 2015
    Andover, MN
    1,729
    I wouldn't run a non-Griot's plate on the G9 - the backing plate was built into the cooling design of the machine. Sure, it's a couple bucks more up front, but it was made for it and you only buy it once. Better to have the right plate than wreck your machine or pads due to overheating.
    For converting your PC to 3", Griot's made an HD 3" backing plate for the last generation GG6 machines that was weighted specifically for that purpose (3" plate on an 8mm orbit machine).
    **googles - Rats - looks like it's been discontinued. **
  15. Likes chilly, PaulMys liked this post
  16. #10
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    As the other guys have said, I would definitely go with the Griot's plate.
    However........ Using the LC plate in a pinch won't end in disaster.
    Just don't be stupid about it and try and use one pad to do an entire car, or to overwork your pads until the point of over-saturation.
  1. Backing plates
    By bonedr in forum Flex Polishers
    Last Post: 06-13-2015, 02:32 PM
  2. Backing Plates
    By Ebg18t in forum Auto Detailing 101
    Last Post: 01-03-2015, 08:45 PM
  3. Bad CG backing plates?
    By BlackHawk in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 03-07-2013, 10:21 PM
  4. Backing Plates
    By gamster in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-28-2007, 08:12 PM
  5. Backing Plates
    By FMINUS in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 05-20-2007, 01:34 PM
