Results 1 to 10 of 10
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,865
    Looking for Better Water Hose and Pressure Washer Fittings
    I am looking for some affordable but long lasting quick disconnect fittings for my water hoses and pressure washer guns, cannon, and hoses
    I am currently on the second set from Amazon after the first set failed in a matter of weeks and they replaced them
    The second set was marginally better, at least the "stainless" balls in the retainer mechanism didn't rust the second time around
    The issue I have is corrosion and oxidation
    The brass is oxidizing horribly, and the coated steel fittings are corroding
    Our water is hard but it certainly isn't corrosive
    The fittings are cheap Chinese crap and I knew better going in
    My bad
    I would prefer some decent stainless fittings but I am not going to go the Obsessed Garage route for a couple of reasons
    Any help or input would be appreciated
    Super Member Buster906's Avatar
    Feb 2016
    871
    Re: Looking for Better Water Hose and Pressure Washer Fittings
    Milton on Amazon is a good brand I am told.
    Sent from my SM-N986U using Tapatalk
  3. Thanks chilly thanked for this post
    Likes chilly, dgage liked this post
  4. #3
    May 2013
    TN
    1,768
    Eley hose fittings are the best I’ve used and very heavy duty. And I mean HEAVY. I won’t own another brand if they continue to make these.
    And Milton is a good brand and what I use for air fittings.
  5. Thanks chilly thanked for this post
    Likes chilly, The Guz liked this post
  6. #4
    Mar 2012
    135
    I have been fighting this battle for years now..... My next option is to go MTM Hydro parts:
    Garden Hose QC - Brass
    Garden Hose Plug - Brass
    They also have stainless but that get's pricey.....
    Also - I'm sure Eley is high quality - but I have 3 hose spots - so need a bulk option = too pricey for my shoes You can even get stainless MTM for cheaper than Eley Brass
  7. Likes dgage, chilly liked this post
  8. #5
    May 2013
    TN
    1,768
    Quote Originally Posted by grovlet View Post
    No kidding. The other thing about Eley brass is they are so heavy, if you needed a weapon, you could bypass the knife and cut off a section of the hose and you’d have a mace.
  9. Likes chilly liked this post
  10. #6
    Mar 2012
    135
    Here's another option - if you are looking for one stop shopping for valves as well:
    Gorilla Quick Connects
  11. Likes chilly liked this post
  12. #7
    May 2006
    Alaska
    1,865
    I will check out all these options and thanks to all you guys for the input
  13. #8
    May 2006
    Alaska
    1,865
    So I have been checking these brands out and I actually considered MTM when I was first setting my system up so I went back and yeah, they are proud of their stuff
    The company is essentially based in Italy and has an enormous plant there so I ASSUME their fittings are made there (seems like most of the spray guns are)
    As I said, they are pricey, so, just for giggles I went on OG and looked at fittings there
    Even more Pricey? Yup, figured that going in
    Made in USA? Nope
    Made in China? Yup, stamped or engraved right on the fitting
    Costs more than a European made MTM fitting and made in China
    I won't go into my rant about OG but guess who I WON'T be buying fittings from
  14. #9
    Mar 2012
    135
    FYI- I have the full MTM setup (Gun / Hose / Fitttings / Nozzles / PF22 Cannon) - had it all for 2+ years now - now to be fair - I'm a hobbyist - and it is not used a ton - but I use it pretty regularly during the warmer months = no issues at all.....
    I don't think they are that pricey - not the cheapest - but customer service is top notch - perfect answer for one stop shopping.
  15. Thanks chilly thanked for this post
    Likes chilly, DFB liked this post
  16. #10
    SELF BANNED
    Jun 2019
    1,076
    Quote Originally Posted by chilly View Post
    My bad
    Contact MTM directly? I have no idea frankly. I wouldn't buy anything from obsessed garage personally. Mosmatic is another highly regarded brand. I have the MTM black hose and SS quick connect fittings it works great. I got it from carzilla in calgary canada. Carzilla sells both brands.- Chris knows his stuff.
  17. Likes chilly liked this post
  1. Snap On Pressure Washer Fittings
    By dirtbikeguy in forum Hot topics & Frequently Asked Questions
    Last Post: 05-15-2017, 06:59 AM
  2. Replies: 0
    Last Post: 12-12-2016, 10:37 AM
  3. Kink free garden hose and pressure washer hose
    By cc rider in forum Auto Detailing 101
    Last Post: 11-09-2014, 08:40 PM
  4. Which pressure washer fittings
    By Madkatz in forum Off-Topic
    Last Post: 08-01-2012, 12:34 PM
  5. Confused about pressure washer fittings !!!
    By Webb in forum Auto Detailing 101
    Last Post: 04-13-2012, 09:46 PM
