So I had a pump sprayer/foamer faze…….
I have been meaning to post a pump foamer review. As you can see I have used the IK 1.5, Foam-it (Ammo NYC) and Marolex Axel 3000.
To start off I will say invest once in an IK foam 12 over any of these. Definitely worth the extra money. Less pumping, better overall coverage. Wish i woulda bought two of those and kept usimg my Round up large wand sprayer in hindsight.
I’ve stopped foaming most liquids except for using BiltHamber AutoFoam and Ammo Frothe. I find, for me, most cleaners and ApC’s work better in liquid form.
Marolex:
1st impression is built well, sturdy. After using it…. Well…. $h!ttY
From the get it had inconsistent foam pattern. Foam was clumpiest of all 3 and used most products.
Tried all the different tips that come with it. Now it’s clogged and just using Ammo Frothe in it. All the other foamers did not have this problem. Would not buy it again.
Also do not like where the spray lock is because i always accidentally engage. Not a big deal but annoying.
Also never been dropped or abused but seam seams to be coming loose. Doesn’t affect performance but QC?
Would not purchase again. Not worth premium price.
IK:
I have the old 1.5 but the spray heads look same inside and out with exception of lock to keep from accidental spray.
Prefer this to lock usage vs Marolex lock to keep spraying.
Build quality is nice but I had one fail at the seam and loose air pressure. Warranty is non existent.
Medium spray works well for Frothe and dry I like with snow foams. Spray pattern is good (Ammo Nicer) and the fan pattern is not too wide. Newest version comes with schrader valve for faster fill ups.
Still not happy with warranty experience I had but it’s a decent product, build quality (feel) is almost nice as the Marolex but it works so much better.
Would buy again.
Foam it/Epoca/Ammo
So i had a problem with first one leaking where release valve is. Ammo replaced it but I wouldn’t count on that every time as the seem impossible to warranty because all companies are from out of country.
Second one has seen most use and has been a consistent piece in my arsenal. The quality of the foam it lays down is most consistent and smooth.
The only drawbacks I see is it has a wide spray pattern so need to get used to distance from surface to control width of fan.
Lastly all the spray heads are molded and put together in 2 pieces. The Marolex and IK have the handle molded in one solid piece connected to bottom piece.
They Ammo/Epoca seam were the two pieces come together runs along length of the handle. Doesn’t feel as sturdy.
Based of performance this would be my first choice but it is also most expensive at $60 from Ammo. It can be found on the Bay from time to time for $35-40 including shipping. The IK can be had from AutoGeek for $43 ($32.75 w/25% off sale)
For price+ performance (long as you don’t need it warranty) the IK is a great value.
Again if i had it all to do over i would save time, effort and money and just buy a IK foam pro 12.
I like pump sprayers for waterless and pretreat. If buying for that i’d buy which ever one is cheapest as the all seam to work well and have a finer mist than the garden ones from Home Depot.
