Results 1 to 6 of 6
    Jan 2022
    Stripping existing waxes/sealants before Ceramic Coating
    I'm going to use the following system before applying the CQuartz. If the dealer has applied a wax/sealant to the paint, will this process remove it?
    Wash with Carpro reset
    Decontaminate with NV Purify and clay
    Carpro Essence
    Carpro Eraser
    CarPro CQuartz
    Carpro Reload
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    You are going to use Essence so that will take care of the dealer applied protection.
  3. Thanks benny3, Dan Tran thanked for this post
    Likes 627PCFan liked this post
  4. #3
    Super Member mwoolfso's Avatar
    Jul 2011
    Long Island, NY
    2,592
    Re: Stripping existing waxes/sealants before Ceramic Coating
    Quote Originally Posted by benny3 View Post
    Wash with Carpro reset **NOT NEEDED**
    Carpro Essence
    Carpro Eraser
    CarPro CQuartz
    Carpro Reload
  5. #4
    Regular Member Epilogts's Avatar
    Jan 2020
    Boulder, CO
    168
    Carpro Essence
    Carpro Eraser
    CarPro CQuartz
    Carpro Reload
    As I understand CarPro Essence is a polish/primer so I’d skip the Eraser step between the Essence and Coating as you’re only going to introduce a risk of marring your perfected surface by the Eraser wipe down.
    For a similar reason I’d also skip the Reload step after coating unless the car is stored outside while the coating cures and you think it might see moisture (But if this is a possibility I’d just wait until you’re sure you can let the coating cure without seeing any moisture). Save the money on Reload and use it for when you feel like you need a little coating “boost”.
  6. #5
    Dec 2011
    Pompano Beach, Fl
    1,494
    I know I’ll probably be pilloried for this but I’ve had good luck going much more simple in the process:
    Wash the car
    Polish with essence
    Put on the CquartzUK
    After 24hrs, any spray ceramic sealant like elixir or blackfire SIO2…..
    Glen -
  7. #6
    Jun 2013
    LA, CA
    8,719
    CarPro recommends a panel wipe even with Essence. It has been mentioned by the reps in the CarPro facebook group. It will not marr the paint and it will not remove the silica left behind. Reload is still the only recommended topped to protect it for the first week while it is curing to prevent water spots. Elixir is not recommended until the first wash.
  8. Likes fries, benny3, Desertnate liked this post
  1. Ceramic Coatings and existing Rock Chips?
    By SupaDoopa in forum Auto Detailing 101
    Last Post: 09-21-2018, 02:17 PM
  2. Are Waxes & Sealants Even Necessary??
    By mattkrmp80 in forum Auto Detailing 101
    Last Post: 03-13-2016, 10:50 PM
  3. Replies: 13
    Last Post: 03-10-2012, 07:38 PM
  4. Stripping Sealants Prior to Polishing
    By ski2 in forum Auto Detailing 101
    Last Post: 01-03-2012, 04:05 PM
  5. Waxes vs Sealants
    By maximus20895 in forum Auto Detailing 101
    Last Post: 05-13-2010, 03:55 PM
