Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Super Member joebruin77's Avatar
    Jan 2019
    258
    Need recommendation for towels for first ceramic coating
    I am preparing to do my first ceramic coating and I need help / recommendations for towels.
    1) What towels do you recommend for the initial leveling wipe as well as for the final "buff"? I plan on getting 2 different colors, one for the first wipe and the second for the final buff.
    2) How often do you have to change your towels when applying the ceramic coating? Do you have to use a fresh set of towels for every panel?
    3) Can you use the same applicator for the entire car, or do you have to use multiple applicators?
    Any advice on how to "manage" your towels during the application of a ceramic coating is much appreciated!
    Thank you,
    Joebruin77
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,231
    Re: Need recommendation for towels for first ceramic coating
    I use the cobra polishing towels that autogeek sells. I have 12 in the red color, and that is plenty for a coating job. I make the color red for coatings only.
    Ya just "know" when to swap out for a new towel. Just like ya do when wiping off a
    polish/compound. No need for different colors for first and final wipe.
    Also look into autosaver applicators. The best for applying coatings. Unfortunately AGO doesnt sell them.
    use same applicator for the entire job
  3. Likes joebruin77 liked this post
  4. #3
    Super Member C5Longhorn's Avatar
    Jun 2015
    379
    I just bought The Rag Company Edgeless 300's to use for my coating. They have a low pile and are economical if I have to pitch or downgrade them to engine duty.
    Sent from my Pixel 3 XL using Autogeekonline mobile app
  5. #4
    Dec 2018
    7,217
    Definitely Autofibers to apply.
    TRC 300 1st towel and 365 for second buff. I usually do a panel to half a panel per side and then flip to clean side.
    I have also used the TRC 245’s with success as 1st towel.
  6. Likes joebruin77 liked this post
  7. #5
    Super Member DFB's Avatar
    Aug 2019
    Australia
    3,256
    I have used both TRC Edgeless 245 and Edgeless 300 for Ceramic coatings.
  8. Likes The Guz, joebruin77 liked this post
  9. #6
    Dec 2018
    7,217
    Quote Originally Posted by DFB View Post
    What were your rhoughts on the 245’s
  10. #7
    Aug 2019
    Australia
    3,256
    They were fine, did the job.
  11. #8
    May 2020
    400
    I used The Rag Company - The Edgeless Pearl 320gsm.
    I bought them from Amazon.
    Only time ever ceramic coating, but they worked well.
    I actually did the 3 towel method and just had them lined up so I knew which one to use first.
  12. Likes joebruin77 liked this post
  13. #9
    Mar 2017
    Southeastern PA
    2,482
    My favorite towels for this are the Gyeon Bald Wipe. They are expensive so it took some time to have about 12 of them (I guess I have at least that many).
    I seem to use about 6 towels per layer of coating, I prefer to change often as that makes the wipe off easier and also immediately soak the towels in a bucket with MF washer and/or APC to avoid letting it cure on the towel. Wash as soon as I'm done with the job, never wait until next day. Then the towels come out clean and ready to use again, I'll re-use them on future jobs and never had an issue. I just can't imagine tossing a $7 towel in the trash every time, especially going through so many during a job.
    To apply the coatings I like the Autofiber coating saving applicators. One applicator (the larger size) has 4 usable areas so I use one applicator for the entire layer of coating, I divide the car in about 4 areas and go that way to avoid using the same spot on the applicator too long. The coating will start to cure there and I want to avoid rubbing it on the paint when that happens.
    Bruno Soares
  14. Likes joebruin77 liked this post
  15. #10
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    What coating are you applying? One coat or two?
  16. Likes The Guz liked this post
  1. Replies: 14
    Last Post: 01-10-2022, 10:42 AM
  2. Replies: 7
    Last Post: 09-30-2018, 08:54 PM
  3. Spray on ceramic coating---how many towels per vehicle?
    By wopachop in forum Auto Detailing 101
    Last Post: 07-29-2018, 10:28 PM
  4. Replies: 8
    Last Post: 03-24-2018, 11:39 PM
  5. Ceramic coating recommendation
    By tailin strange in forum Auto Detailing 101
    Last Post: 11-24-2017, 05:44 AM
