Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Apr 2020
    60
    clear coat tape line
    hey guys just got my car repainted due to an accident or more like a blend job that was done on the doors....its a tape line and the lip isn't that drastic if you pass a finger over it but it is there. how can I remove or make it less noticeable? I also noticed from the tape line there is some dullness possible paint with no clear then the factory clear again..
    clear coat tape line-img_8123-jpg
    Super Member Bosko's Avatar
    Oct 2021
    Michigan
    1,584
    Re: clear coat tape line
    I'd take it up with whoever did the work and tell them your issues and have them make it right.
  3. Likes JKDesign liked this post
  4. #3
    Apr 2020
    60
    Paint shop says it’s fine and won’t take responsibility, was wondering if this job can be easy enough for a diy car enthusiast to tackle and hide it as much as possible?
  5. #4
    Jan 2015
    Simi Valley, CA
    1,783
    Quote Originally Posted by nick27 View Post
    Paint shop says it’s fine and won’t take responsibility...
    This quoted part of your post tells me that the paint shop's standards are somewhat different than yours. And mine.
    If I'm interpreting your photo correctly, I see a tape-edge and shadow ~1/2" in from the edge of what I'm assuming is the rocker panel (door sill). Is that correct?
    If so, I see a few options...
    1) Sand the area with 1500-3000 grit just enough to smooth it out and then compound/polish the area.
    2) Sand the area with 1500-3000 grit to remove all of the offending paint back to the outer edge. You could also try removing it with solvent (lacquer thinner, acetone, etc,), or some combination of solvent and sanding. Then compound/polish the area. Doing this will move the paint blend edge to the edge of the panel where it will be much less noticeable.
    3) Sand the blend area and the rest of that entire panel section (between edges) with 1500 grit and then spray the entire panel section (between edges) with a urethane 2k clear (available in spray cans).
  6. #5
    Apr 2020
    60
    I’ve tried using some fg400 on a microfibre rag and buff by hand and what I noticed is the clear does come off and to my assessment , there is clear under that one….will I be able to blend them both together without moving the tape line outside the body line? Or will this clear flake off….
  7. #6
    Jan 2015
    Simi Valley, CA
    1,783
    This sounds like you're going down the path similar to my #2 suggestion above. Keep going until you have moved the blend to the edge of the panel. Most likely you will not be able to remove the blend edge altogether, but if you can move it to the edge of the panel by sanding/compounding/polishing, that is where it will be the least obvious to the eye.
  8. Likes JKDesign liked this post
  9. #7
    Apr 2020
    60
    Quote Originally Posted by 2black1s View Post
    This sounds like you're going down the path similar to my #2 suggestions above. Keep going until you have moved the blend to the edge of the panel. Most likely you will not be able to remove the blend edge altogether, but if you can move it to the edge of the panel by sanding/compounding/polishing, that is where it will be the least obvious to the eye.
    If by moving it to the edge of the panel will that cause the clear to chip or flake off?
  10. #8
    Super Member JKDesign's Avatar
    Oct 2016
    Portland, ME
    316
    No, the shop has (or should have) scuffed/sanded the top of the original clear coat down to provide something for the new cleat coat to bite into. Compounding it back to the edge just moves it to an area that will be less noticeable. Also- if the shop is reputable- they should provide a guarantee on the work for as long as you own the vehicle. Honestly- if you are not happy with the offending line- they should be the ones to clean up their mess.
  11. Likes Bosko liked this post
  12. #9
    Oct 2021
    Michigan
    1,584
    Quote Originally Posted by JKDesign View Post
    This!
    This is the second post regarding someone saying the.."Shop told me"...it was fine.
    BULLSHIT!....they make it right period
  13. #10
    Oct 2016
    Portland, ME
    316
    Bosko- I have worked in the collision industry for 15yrs- as a technician, a detailer, a manager, and as an estimator. My bottom statement is something that I have always stuck with- and for the current shop organization that I work for- we provide it in writing for every customer and every job!
  14. Likes Bosko liked this post
  1. Clear coat tape lines?
    By Indiglofish61 in forum Ask your detailing questions!
    Last Post: 09-08-2018, 08:06 PM
  2. Replies: 2
    Last Post: 06-11-2016, 03:42 PM
  3. Can clear coat line from removed pinstripes be sanded down?
    By boarderx in forum Auto Detailing 101
    Last Post: 05-19-2015, 07:28 PM
  4. How many tape raised body line while using DA?
    Last Post: 02-22-2013, 05:13 PM
  5. Tape pulled clear coat off
    By cpmx450 in forum Ask your detailing questions!
    Last Post: 03-18-2012, 07:45 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
