Re: TW HS Acrylic tire spray coating.
I applied liberally the first time road
Okay 2 more light coats last night and dried/soaked in overnight
Looks darker/wet in person which I like will be curious to see how it holds up
you got a good black for sure
Now all I did was use the "auto" setting on my phone, not like Bosko ofcoarse but another look
2022 Elantra N Cyber Gray
Originally Posted by
vaca22
I used Black Magic Tire Wet the other day! LOL!!
Is that the stuff that makes tires super sticky?
If so, my grandpa had some so I used it since it was available at the time and GAH DAMN! That stuff is terrible! It stuck like a clear glue onto my tires and got onto my wheels and turned them sticky and black. Even thought it’s so sticky it also somehow slung onto the side of my car and left black sticky marks that only came off with bug/tar remover. Also used the bug/tar remover to get it off my wheels. Had to reapply my winter protection (Meg’s HCW spray) after using the remover to get all the gunk off the side of my car and wheels.
Also, as it wore off the tires it came off in patches, so parts of the tire looked dark/wet and other parts looked like naked tire.
Never again.
BLM thanked for this post
seabiscut88
I’ve cleaned tires quite a bit for tire coatings (Tuf Shine, Pinnacle) and they recommend to keep cleaning until the tire no longer turns brown when cleaning. But in all that time, I never had a tire be that brown but I also haven’t coated large truck tires. But my thought is you need to clean your tires more until not as much brown comes out. That might help with the look of your tires before applying the TW HS coating and may improve the look and longevity. Just a thought. But good stuff, looks a lot better now.
Also, this is called a tire coating and yet you mention it is soaking in. Tuf Shine and Pinnacle look like an applied coating and dry but don’t really soak in. So I’m a little confused on whether the TW HS tire spray is actually a coating. Will be interesting to see more results over time. One way to easily tell a tire coating is if you rub up against the curb because the coating comes off in that area only.
Personally I don't think this is a coating at all. IMO this is a result of a company getting back in the game and using a "buzz word". I see a boardroom of corporate types throwing around terms they've read about online, FaceSpace groups, etc. My thing is don't try and be hip, just be solid and they have for the most part.
Tire coatings I've used have that blueish/purple stuff in the mix, hell they should know what a coating is, they made a great one about 5 yrs ago
I agree this is not a coating. I’ve used two true tire coatings and they go on differently and set up differently. This is just another dressing, it may be a good one, but I think it’s just a dressing.
