Paint protection advice
I purchased a new vehicle a couple months ago and did mechanical decon and put dgps and topped the next wash with sonax bsd as I planned to fully decon, polish, and cquartz the car this week. Unfortunately my available time has changed and I will not be able to get that accomplished anymore. My question is what would be better option to do with shorter period of time prior to the winter snow and salt. Options I see are wash with reset, mech decon and apply new layer of dgps and some sort of wax topper or wash with reset, iron x, mech decon and apply cquartz without polishing paint as that is the step I really wont have time to accomplish. I could order some other product today with faster shipping if recommended. I would have to wait till probably May before I would have time polish paint and coat with original plan.
Re: Paint protection advice
II'd go with a ceramic/graphene spray at this time
Griot's 3 in 1
Griot's Garage Ceramic 3-in-1 Wax
Adam's Graphene advanced
404 Not Found - Adam's Polishes
Blast around the car with a paint sealant or collonite 845. Speedy and great protection. I have no experience with the 3-1 but everyone loves that too. Another great option
Get a beater to drive in the nasty weather conditions
opie liked this post
Wash, Iron-X, wash, wipe down twice with Kleen-Strip Prep All (avaliable at local auto parts store) then Gyeon Can Coat.
By the end of the week the posts will read like this
Strip the paint with 800 grit, 2 coats of water based primer...followed by 4 coats of base topped with 6 coats of clear.
Color sand and then polish with a 2 step to provide clean smooth base.
Now top with ceramic coat allowing 7 days of cure without water exposure to the weather
Originally Posted by
kingweb50
If I understand you correctly, you just recently applied a good layer of Wolfgang DGPS and then topped it BSD a little later? How long ago was this?
My vote is to leave the vehicle as-is and simply top with more BSD or a good spray sealant if you really feel the need. DGPS should last you a good six months and get you though most of the winter.
Re-evaluate what you want to do in the spring when the weather warms up and better suited for detailing.
The paint sealant that is on there right now would probably be just fine through the winter.
Could could apply a fresh coat, or order a bottle of something like Duragloss 101, which would remove the previous sealant, and lay down something that will likely make it through the winter.
Desertnate
Indeed, sometimes doing nothing is better than doing something!
If time is short one of the MANY top shelf spray sealants will treat you well enough. So many options I can't keep up myself. For me if time is short I grab the Carpro Reload. Longevity isn't great but it only takes minutes to do an entire vehicle while drying. I can stomach the weak durability cause it's easy to apply every or every-other wash.
But, as many have said, it sounds like you have a decent layer of protection as it is.
2019 GLI 35th Edition DSG in Pure Grey w/ OEM+ IS38 turbocharger and various bolt-ons.
