Buy a ipa or make it?
So when it comes to ipa what is everyone using? Are you making your own or buying it? I watched mikes video on making ipa and he uses 4 oz of 91% alcohol. How long will this last in the bottle with water ? Will it evaporate over time? If you make your own how much alcohol you mixing?
Re: Buy a ipa or make it?
I suspect you are asking about an IPA "solution". As long as the bottle is airtight you won't get constant oxidation of the alcohol, so "no". And yeah, you have to mix it simply because you don't need a lot of it for the task at hand. Cheers.
I take a Windex bottle, figure how many ounces are in it and put in 40% alcohol and 60% water, it’ll keep for years on a shelf in air-conditioning. I have a ton of uses for it.Put me on the side for using IPA as a paint cleaner/prep… I bought eraser and don’t wanna pay for something that I can get with IPA. I’ve used IPA on every prep job for the last 15 years and never had a problem.
I am a strong believer in purchasing panel preps over homemade alcohol mixes for paint. Personally (for me) if it is important enough, where I need a surgically clean surface PRIOR to applying protection, the financial investment of an appropriate chemical solution is minor.
The question is.....what other ingredients are in a "panel wipe"....most are labeled as inert material which in my book is WATER!
Why pay for water in a store bought panel wipe?
Steer me if I'm wrong as I'm not well versed in panel wipes as I have always made mine...
At $5 a quart for 90%....it sure makes a bunch CHEAP if you make your own
I agree with you for the most part but on softer paint, stubborn to remove polish/compounds ie product, climate or just out of the blue issues I think the panel prep offerings offer a more fluid wipe off. They seem to wipe off easier, I will say it’s best to use whatever solution you want as you go. I like to use the ipa before any of the oils/carriers have a chance to dry.
I also find my towels leave less dust on the panel with Erasure, for some reason when I use ipa it seems I get more towel shedding
All we them to do is tell us what that other ingredient is....sneaky bastards...lol
Super Moderator
What are you using the IPA for? If you're using it to remove polishing oils after paint correction and before applying a coating than I would suggest using a dedicated paint prep spray. Much safer to use and less chances of marring the paint surface.
Gtechniq, Gyeon, CarPro, OPtimum, Meguiar's, Mother's, Poorboy's, 3D, IGL, P&S, Marine 31, Blackfire, Wolfgang, Pinnacle Black Label, and DP offer paint prep sprays.
BLACKFIRE Paint Prep
Rod73 thanked for this post
CarPro Eraser is what I use. I've tried N-914 at panel wipe ratio but found it foams/suds too much. Eraser works well and smells great too.
Gyeon Prep is my Go To. There are many brands that accomplish the same thing. I have had great success with Gyeon Prep.
CJ
Save the Manual!
By MadMax in forum Auto Detailing 101
Last Post: 04-23-2016, 08:41 PM
By b0b in forum Ask your detailing questions!
Last Post: 10-05-2013, 01:45 PM
By WallStGuru in forum Auto Detailing 101
Last Post: 09-13-2012, 03:42 PM
By Mike Phillips in forum Off-Topic
Last Post: 07-12-2011, 09:06 AM
By James K in forum Off-Topic
Last Post: 02-28-2011, 06:10 PM
