Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 67
  1. #21
    Super Member CleanIT's Avatar
    Aug 2019
    1,842
    Re: New Opti-Coat Hyper Seal
    Quote Originally Posted by oneheadlite View Post
    What car wash are you using? Just playing devil's advocate, Any chance it's not rinsing fully thus covering up Hyper Seal's behavior?
    I was using Optimum Car Wash. I even went back over it again and it was dead. Even before the wash the hydrophobics were very poor. I must not have done something right. I did a full decon, strip with OPC, polish and paint prep with Gyeon Prep. I did put a second layer on 8 hours later, which per OPT is fine. Only needs an hour to set. I'm debating on whether to give it another shot or just use something else I have on hand.
  2. #22
    Super Member Mgavin1985's Avatar
    Nov 2017
    497
    I think hyper seal and opti seal are basically the same. I have opti seal and only thing I use it is on interior glass as cleaner. It was not a good sealant
  3. Likes CleanIT liked this post
  4. #23
    Aug 2019
    1,842
    Quote Originally Posted by Mgavin1985 View Post
    I have to say I can't even believe it qualifies as a sealant. I found Opti-Seal to be extremely weak. The new Hyper-Seal, which is what I used, is supposed to be significantly better than the old but who knows.....I love the look of both but water behavior is not impressive at all. I'm disappointed so far because i really like the look of it and how it goes on.
    I noticed some differences between Wet Coat, HCD, OS and Hyper-Seal. Beads would fly off the paint around 15 mph with HCD, 40 mph for Griot's 3 in1 and around 25 mph with Wet Coat and no movement with Opti-Seal or Hyper-Seal so far. I know it sounds ridiculous but it is something I've noticed.
  5. Likes dwaleke liked this post
  6. #24
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by NJNinja View Post
    Not sure what to make of this. Did a quick wash last night. Zero protection left. Could the solvent in HS have dissolved remaining protection I didn’t completely remove? Clearly didn't bond properly. Or Hyper Seal is that weak....which I find hard to believe. Opti-Seal only lasted 2 weeks for me.
    Optimum and the reps would point the finger at you for not using any optimum polish during the prep process. This has always been their cop out when their products under perform. Just like when they pointed the finger at M205 when using Gloss Coat when it underperformed.
    Looks good homeslice on initial but bad durability I seeI tend to rant on and on about opti and the underwhelming Gloss Coat and how they should make something better. Plus it’s $60 for 10mls
    Exactly. Gloss Coat was rather underwhelming from my experience with it. I gave Opti-Seal away as well. The upside is the ease of use. I recall when Yvan was at Optimum how they boasted that their coatings required no topper and then Hyper Seal shows up haha.
  7. Thanks CleanIT thanked for this post
  8. #25
    Aug 2019
    1,842
    Thanks Guz, good to know. I prepped the paint like I always have and never had this issue with any other product.
  9. #26
    Oct 2010
    97
    I've been using the new formula Hyper Seal since April. Initially I did a full decon & polish before applying two coats of Hyper Seal. Since then I wash my truck once a month and use Hyper Seal as a drying aid. Here is a pic I took a few minutes ago after a rain shower. The truck was last washed about 10 days ago. It has been driven over 700 miles since then & spent three days at the beach so it is covered in bugs & salt spray. No other products have been used other than Hyper Seal.
  10. Likes CleanIT, dlc95 liked this post
  11. #27
    Aug 2019
    1,842
    Looks good AMarkham40. I don't know what to make of my situation. I'm highly confident I did things exactly as they should be done.
  12. #28
    Super Member Azure's Avatar
    May 2013
    Indianapolis, IN
    405
    I have to say I can't even believe it qualifies as a sealant. Opti-Seal is extremely weak. The new Hyper-Seal, which is what I used, is supposed to be significantly better than the old but who knows.....I love the look of both but water behavior is not impressive at all. I'm disappointed so far because i really like the look of it and how it goes on.
    Yeah, even BeadMaker will still have some protection left after that short of time. That's crazy! I did like Optimum Spray Wax and it has lasted with Topper as a drying aid since early Spring on my wife's car.
  13. Likes CleanIT liked this post
  14. #29
    Oct 2010
    97
    I would give it another shot before throwing in the towel. I used 3D HD Polish+ then CarPro Eraser to make sure all the polishing oils were removed before applying Hyper Seal the first time. Now, I agree Hyper Seal is grabby when initially applied. I was told by an Optimum rep that slickness would improve after using the product as a drying aid a couple times. He was correct.
  15. Thanks CleanIT thanked for this post
  16. #30
    Mar 2009
    99
    Did you keep the car dry for 24 hours after application and before you attempted to wet it to test beading and wash it?
  1. Optimum Gloss Coat vs Opti-Seal 2.0
    By timsatx in forum Hot topics & Frequently Asked Questions
    Last Post: 03-03-2016, 09:04 PM
  2. Re-Painted F150 vs. Optimum Hyper Polish & Opti-Coat 2.0
    By Nick McKees37 in forum Show N' Shine
    Last Post: 12-20-2014, 11:21 PM
  3. Optimum Hyper Polish spray & opti seal
    By surajprasade in forum Ask your detailing questions!
    Last Post: 12-17-2011, 10:19 AM
  4. Opti-Coat/Opti-Guard and Poli-Seal Problem
    By gmck in forum Auto Detailing 101
    Last Post: 11-29-2011, 07:33 AM
  5. Experience with Opti-Coat and Poli-seal
    By dougaross in forum Auto Detailing 101
    Last Post: 06-06-2011, 06:34 AM
