Results 1 to 8 of 8
    Super Member KBsToy's Avatar
    Jul 2011
    SW...Pa
    1,490
    Another coating question :)
    I know this question has been asked before but with fall and winter coming, I would like to ask your advice on the new coatings that are out there now and which would be easiest to use for this weekend warrior .
    Thanks
    KB
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,450
    Re: Another coating question :)
    IMO Cquartz UK 3.0 or Cquartz SiC. Both are super easy. In fact lay down a layer of UK then SiC. What's nice is when you use CarPro Essence, it is not only a polish and filler product that enhances gloss and the micro swirls polishing puts in but it's a base-coat layer of SiO2 for the next layer/your coating. It leaves a slick surface but that's not the end of it. When you put on UK 3.0 the surface becomes a slight bit more grabby vs Essence so you can literally feel where you need to coat. If you layer SiC on next, it goes on super slick and thus you can again, feel where you have UK 3.0 as your first layer and then SiC as your second.
    Flash times will vary but UK does allow for longer and is more forgiving. However, you won't have a problem with SiC. Both have carrier solvents that are easy to wipe.
    2023
  3. Thanks KBsToy thanked for this post
  4. #3
    Super Member 98CayenneTA's Avatar
    Aug 2020
    Minnesota
    593
    Quote Originally Posted by TTQ B4U View Post
    This really is a amazing combo.
    Ripping through your mind like a hurricane full of novocaine
  5. Thanks KBsToy thanked for this post
  6. #4
    May 2013
    TN
    1,768
    There are a ton of coatings out there but CQuartz UK 3.0 is a stalwart and I also went with a second coat of SiC to give more chemical/water spotting resistance.
  7. Thanks KBsToy thanked for this post
  8. #5
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    I agree that CQUK 3.0 is easy. SiC is a little trickier because of the long flash times. It has up to 8 mins and you will have to figure out when it is the right time to wipe off.
    Others I would toss in as they are 1 layer coatings.
    Poorboys Ceramic which is the slickest coating I’ve used as of late. Yes even slicker than SiC.
    Blackfire Black Edition which will act a little like Gtechniq CSL where it has a swearing effect indicating it’s time to wipe off.
    DP Graphene which will rainbow. Very nice to work with.
    You always have the Gtechniq twins but now your approaching multi layer.
  9. Thanks KBsToy, Goonie75 thanked for this post
  10. #6
    SELF BANNED
    Jun 2019
    1,076
    Whats the water behavior like for poorboys Mike? Its a great price for a claimed 3 year coating.
  11. #7
    Dec 2018
    7,225
    Being your first time Cquartz would be ok but finding right removal can be tricky 60 seconds to 4 mins.
    There are alot of coatings that you can apply and remove instantly. I would look into those.
  12. Thanks KBsToy thanked for this post
  13. #8
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by noorth View Post
    Comparable to most coatings.
  14. Likes noorth liked this post
  1. Question on McKees 37 coating, hell any coating for that matter...
    Last Post: 07-29-2018, 04:29 PM
  2. Coating question?
    By Mgavin1985 in forum Auto Detailing 101
    Last Post: 06-22-2018, 08:43 AM
  3. Coating question
    By rmcnamara in forum Auto Detailing 101
    Last Post: 01-17-2017, 04:02 PM
  4. Coating question - layering an Optimum Product over a CQUK coating
    By LSNAutoDetailing in forum Auto Detailing 101
    Last Post: 07-10-2016, 04:33 PM
  5. Question about coating
    By Mikas46 in forum Auto Detailing 101
    Last Post: 12-13-2013, 02:18 AM
