Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Mar 2018
    Conroe, Texas
    477
    Anyone tried the new headlight kits?
    I have a test vehicle I want to try to correct the headlights with one of the new kits from Griot's Garage or Diamondite. Does anyone know if they would work for turning these lights back to clear?
    I am proficient with sanding method but would like to try these new chemical based kits to see if they really do work without the sanding step.
    My test vehicle was done over 2-years ago and has yellowed:
    Will the entry level kit work or need the kits with sanding step?
    Feb 2012
    Palatine Illinois, USA
    24,547
    Re: Anyone tried the new headlight kits?
    I used a Griot's Garage headlight resto kit on my ex's 2007 Mazda 6 about 4 years ago. The car was traded in Dec of 2019 and after 2 years they still looked great!
    I see Griot's Garage has a new ceramic kit in 2 levels of restoration needed, I'd have no hesitation to use one of those kits as I'm sure Griot's Garage made them even betterAnyone tried the new headlight kits?Anyone tried the new headlight kits?
    I should tell you these lights were so bad you had to use the brights to drive at night, so not only does it make the car look better but SAFERAnyone tried the new headlight kits?Anyone tried the new headlight kits?
    2022 Elantra N Cyber Gray
    Jan 2014
    SoCal
    1,122
    Those don't look that bad. I wouldn't waste your money. Just hit them with a wool pad and some compound; finish off with foam and polish. Nobody that I've seen makes a good sealant. I would just use some leftover coating and redo in a couple years.
    Aug 2013
    St Louis metro (Illinois)
    5,809
    So a kit with nothing more than some wipes will actually remove the hazing and yellowing of the lenses? The spray product in the Griots kit appears to be the final sealant/coating.
    I've never sanded lenses, but have used a polisher and the polishes included in the Wolfgang headlight kit. I thought that yellowing/haze would need at least some sort of abrasive polish to remove. On my daughter's Mazda3 it's pretty stubborn.
    Sep 2020
    Eastern PA
    1,791
    The new Griot's kits come with ceramic wipes in place of the spray on clear coat the old kits came with.
    I actually have the new moderate kit that I got for the headlights on my gf's car (Mazda 3). I may try that out at the end of the month. Will report back with before/after pics.
    Feb 2012
    24,547
    The one I used had a square with L and R on it and the small can of clear. You spray water constantly on it while sanding, wipe it away and dry, tape off the whole area real good, evenly spray it on and let dry in the sun for a couple hours...doneAnyone tried the new headlight kits?Anyone tried the new headlight kits?
  7. Thanks Desertnate thanked for this post
  8. #7
    Aug 2013
    5,809
    Interesting. So the squares are actually a really mild sandpaper?
  9. Likes Klasse Act liked this post
  10. #8
    Feb 2012
    24,547
    Yes they are and my ex's headlights were B A D and it did an amazing job, I'll try and find picsAnyone tried the new headlight kits?
  11. Thanks Desertnate thanked for this post
  12. #9
    Feb 2012
    24,547
    Here's the pics of my results with the Griot's Garage kit from a couple years ago:
  13. Thanks Desertnate, Caraman thanked for this post
    Likes PaulMys liked this post
  14. #10
    Feb 2012
    24,547
    I should add that these headlights were also very dry and crusty as well as fadedAnyone tried the new headlight kits?
  1. Headlight restoration without kits
    By theblob640 in forum Auto Detailing 101
    Last Post: 07-06-2013, 07:04 PM
  2. Headlight Restore Kits
    By kirkatizer in forum Auto Detailing 101
    Last Post: 11-26-2012, 04:45 AM
  3. headlight restoration kits
    By bk2nrml in forum Auto Detailing 101
    Last Post: 06-12-2011, 04:13 AM
  4. Are all headlight restore kits the same?
    By Rhudeboye in forum Auto Detailing 101
    Last Post: 11-24-2010, 08:24 PM
  5. headlight lense kits
    By Flyboy in forum Auto Detailing 101
    Last Post: 11-30-2006, 09:25 PM
